Date/Time: Fri, 24 Jan 2025 00:27:12 +0000
DOM bar graph problem
View Count: 769
[2018-12-11 15:09:03] |
User913831 - Posts: 37 |
Hi I am having a problem on the DOM chart, the histogram of the bar representation of the ask and bid is not the same at a similar level. Please see picture Can you help Thanks Date Time Of Last Edit: 2018-12-12 08:25:26
[2018-12-11 15:23:46] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-12 07:39:43] |
THx please see attached file
[2018-12-12 08:24:13] |
Okay what you are looking for is not supported by Sierra Chart. The width of those volume bars is based upon the particular side.
[2018-12-13 14:43:02] |
Hi, So to be clear, my problem is that the lengh of the bar histogram is not proportional to quantity for ask and bid. For instance for a volume of 120 at 22669.76 the bid s histogram representation is 4 time higher than the ask at 116 at 2670.75. Also the Sell and Buy figures appears to be correct. I am confuse with your answer as If you don t support this part of the software, could you please indicate who does? Thanks |
[2018-12-18 14:51:55] |
HI, I am having serious problem that stops me from working, for some reasons the DOM Volume bar of either Bid or ask fail to remaind accurate. On the attach file you can see 2 Dom pictures taken within the same minute. I need to relaod a different symbol and back to the original one to reload those volume bar which can only remain accurate for some time. I would appreciate a fix Thanks |
DOMpb1.jpg / V - Attached On 2018-12-18 14:46:21 UTC - Size: 525.26 KB - 312 views |
[2018-12-19 04:03:53] |
One thing we will make sure about is that the width of the market depth quantity volume bars, be based on the highest and lowest quantities at that moment.
