Date/Time: Thu, 23 Jan 2025 18:16:38 +0000
minor tool bar issue
View Count: 866
[2018-12-11 14:25:32]
User98657 - Posts: 329
I have a minor tool bar issue. Normally i show three detached charts on a monitor. they all contain the same Control Bar. One chart takes up roughly 2/3 of the monitor, the other two are sized to take equal parts of the remaining third.
While sized to fit the screen as described above, the Control Bar is too long to allow all its buttons to be displayed across the tops of the charts so i only see part of the buttons. This is obviously understandable, there isn't enough room to display all the buttons. However, when i maximize the chart, the Control Bar does not expand. i can still only see the minimal number of buttons assigned to the Control Bar. i have to then right click, "customize Control Bar 2", and then click OK after which the Control Bar is able to display all the buttons.
I don't believe this is a new issue. Its been like this as long as i can recall. Not a critical issue, obviously, just an annoyance.
[2018-12-11 15:34:34]
This should already be resolved. Update Sierra Chart to the current version:
