Date/Time: Thu, 23 Jan 2025 18:17:00 +0000
no last size text shown in DOM
View Count: 652
[2018-12-11 01:58:18]
User929952 - Posts: 3
as seen in pic
I can't see last size in DOM
thanks,
imageDOM-lastsize.JPG / V - Attached On 2018-12-11 01:57:43 UTC - Size: 44.28 KB - 274 views
[2018-12-11 15:40:17]
John - SC Support - Posts: 37437
Most likely you have the color settings for the Last Size set such that you cannot see the text. Refer to the following section and the sections following it for where these colors are set. You will want to look at the Background color and the Text color:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart DOM Last Price Text Bid Trade
If this is on the Trade DOM and not the Chart DOM, then start here:
Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Trade DOM Last Price Text Bid Trade
And finally, be sure you are modifying the correct Graphics Settings. If you have selected specific Chart-based Graphics Settings, then be sure to change the settings in the Chart >> Graphics Settings section rather than in Global Settings >> Graphics Settings. Refer to the following for help with Chart versus Global Graphics Settings:
Graphics Settings: Use Global Graphics Settings Instead of These Settings
