Date/Time: Thu, 23 Jan 2025 18:24:02 +0000
DOM DLyPL
View Count: 647
[2018-12-10 22:04:33] |
CodyH - Posts: 2 |
Hello My DlyPL on my DOM is not functioning properly, it does not give real data on the trades wins and loss and jumps all around. Is there a way to fix this? |
[2018-12-10 22:18:51] |
Refer to: Help With Daily Profit/Loss Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-11 03:58:18
[2018-12-11 02:59:54] |
Sierra Chart - Max - Posts: 5779 |
From User: The issue is the DlyPL is incorrect.
For instance, I close a trade for 10 points, it will say negative 53 or some random number. If I lose a trade for 3 points it could say positive 100 points. It just doesn't seem to be calculating or displaying any of the proper data Sierra Chart Support |
[2018-12-11 04:00:18] |
You need to go through the step-by-step documentation here: Help With Daily Profit/Loss Value We do not provide any further support than this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
