Date/Time: Fri, 24 Jan 2025 08:40:58 +0000
[User Discussion] - Bitmex - ReduceOnly for attached orders
View Count: 816
[2018-12-10 20:09:38]
anpy - Posts: 35
There are two bitmex-specific options for attached orders (ReduceOnly limit & stop) in the Data/Trade Service settings which work as intended when the attached orders are submitted along with a new order. However the ReduceOnly instruction will be ignored if the attached orders are submitted separately using "Send Attached Orders-Position".
[2018-12-10 21:40:25]
anpy - Posts: 35
not sure why this would be a user discussion, I consider it a bug.
Date Time Of Last Edit: 2018-12-10 23:37:03
[2019-01-16 09:27:58]
anpy - Posts: 35
Please consider implementing this so manually sent attached orders will behave the same as automatically sent attached orders. All it needs is to tag (manually) attached limit orders with the ReduceOnly execInst, if the corresponding option is enabled (Data/Trade Service Settings > Specify Reduce Only for Limit Attched Orders).
Date Time Of Last Edit: 2019-01-16 09:43:42
[2019-01-16 10:28:59]
anpy - Posts: 35
Just noticed that the alert settings for Target Filled/Stop Filled are also ignored if attached orders are sent separately.
(General Trade Settings > Play alert when target filled/stop filled)
Date Time Of Last Edit: 2019-01-16 10:30:49
