Date/Time: Thu, 23 Jan 2025 18:10:43 +0000
How to hide SCSrting value in dll if use text viewer?
View Count: 586
[2018-12-10 18:23:18]
User517260 - Posts: 97
Dear Support, I use SCSrting variable UserName in my study.
SCString InternalUserName   = "ACxxxxxx";
I used Notepad++ to look at dll code, opened my dll and found there ACxxxxxx. How I can hide this UserName - I don't want to show it in dll for everybody. Thanks!
Waiting for your reply, Alex.
[2018-12-10 19:25:45]
You need to remotely request this data from a server you set up using this function:
sc.MakeHTTPRequest()
This will always be considered the best proper practice or have the user enter the data.
Date Time Of Last Edit: 2018-12-10 19:26:02
[2018-12-11 09:46:32]
Thanks!
