Date/Time: Fri, 26 Apr 2024 16:25:51 +0000
ACSIL howto get working OrderID/FilledPrice in ReplayMode (Sim)
View Count: 8659
[2018-12-09 17:29:34] |
TedMar - Posts: 189 |
Hi, im not understand how i can get OrderID and FilledPrice from manual placed Order in Replay mode. 1.) i tryit like this manual Automated Trading From an Advanced Custom Study: sc.GetOrderByIndex to get Open OrderID But i get still InternalOrderID == 173365328 2.) Im not sure , but is OrderID needed o get AvgFillPrice from s_SCTradeOrder Structure Members? Automated Trading From an Advanced Custom Study: [Type: double] AvgFillPrice 3.) sc.GetOrderFillEntry(0,FillPrice) together with sc.GetOrderFillArraySize() result is 0 |
[2018-12-14 17:38:19] |
1. Looks like you are checking the Service Order ID member instead or somehow not interpreting it properly. 2. Yes. 3. We will see if we can put together an example for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-14 17:38:44
[2018-12-17 05:30:34] |
3. Here is the code example: SCSFExport scsf_GetOrderFillEntryExample(SCStudyInterfaceRef sc)
{ //Define references to the Subgraphs and Inputs for easy reference. //In this particular example, these are not used but this study is configured as a typical trading study. SCSubgraphRef BuyEntrySubgraph = sc.Subgraph[0]; SCSubgraphRef BuyExitSubgraph = sc.Subgraph[1]; SCSubgraphRef SellEntrySubgraph = sc.Subgraph[2]; SCSubgraphRef SellExitSubgraph = sc.Subgraph[3]; SCInputRef Enabled = sc.Input[0]; if (sc.SetDefaults) { // Set the study configuration and defaults. sc.GraphName = "GetOrderFillEntry Example"; BuyEntrySubgraph.Name = "Buy Entry"; BuyEntrySubgraph.DrawStyle = DRAWSTYLE_ARROW_UP; BuyEntrySubgraph.PrimaryColor = RGB(0, 255, 0); BuyEntrySubgraph.LineWidth = 2; BuyEntrySubgraph.DrawZeros = false; BuyExitSubgraph.Name = "Buy Exit"; BuyExitSubgraph.DrawStyle = DRAWSTYLE_ARROW_DOWN; BuyExitSubgraph.PrimaryColor = RGB(255, 128, 128); BuyExitSubgraph.LineWidth = 2; BuyExitSubgraph.DrawZeros = false; SellEntrySubgraph.Name = "Sell Entry"; SellEntrySubgraph.DrawStyle = DRAWSTYLE_ARROW_DOWN; SellEntrySubgraph.PrimaryColor = RGB(255, 0, 0); SellEntrySubgraph.LineWidth = 2; SellEntrySubgraph.DrawZeros = false; SellExitSubgraph.Name = "Sell Exit"; SellExitSubgraph.DrawStyle = DRAWSTYLE_ARROW_UP; SellExitSubgraph.PrimaryColor = RGB(128, 255, 128); SellExitSubgraph.LineWidth = 2; SellExitSubgraph.DrawZeros = false; Enabled.Name = "Enabled"; Enabled.SetYesNo(0); Enabled.SetDescription("This input enables the study and allows it to function. Otherwise, it does nothing."); // This is false by default. Orders will be simulated. sc.SendOrdersToTradeService = false; sc.AllowMultipleEntriesInSameDirection = false; //This must be equal to or greater than the order quantities you will be submitting orders for. sc.MaximumPositionAllowed = 10000; sc.SupportReversals = true; sc.AllowOppositeEntryWithOpposingPositionOrOrders = true; // This variable controls whether to use or not use attached orders that are configured on the Trade Window for the chart. sc.SupportAttachedOrdersForTrading = false; //This variable controls whether to use the "Use Attached Orders" setting on the Trade Window for the chart sc.UseGUIAttachedOrderSetting = false; sc.CancelAllOrdersOnEntriesAndReversals = false; sc.AllowEntryWithWorkingOrders = false; sc.CancelAllWorkingOrdersOnExit = true; sc.AllowOnlyOneTradePerBar = false; //This needs to be set to true when a trading study uses trading functions. sc.MaintainTradeStatisticsAndTradesData = true; sc.AutoLoop = true; sc.GraphRegion = 0; return; } //These must be outside of the sc.SetDefaults code block since they have a dependency upon an actual chart object existing sc.SupportTradingScaleIn = 0; sc.SupportTradingScaleOut = 0; if (!Enabled.GetYesNo()) return; if (sc.LastCallToFunction) return;//nothing to do int& PriorOrderFillEntrySize = sc.GetPersistentInt(1); int CurrentOrderFillEntrySize = sc.GetOrderFillArraySize(); if (CurrentOrderFillEntrySize != PriorOrderFillEntrySize) { PriorOrderFillEntrySize = CurrentOrderFillEntrySize; if (CurrentOrderFillEntrySize > 0) { s_SCOrderFillData OrderFillData; sc.GetOrderFillEntry(CurrentOrderFillEntrySize - 1, OrderFillData); SCString OrderFillMessage; uint32_t OrderQuantity = OrderFillData.Quantity; OrderFillMessage.Format("New order fill: InternalOrderID = %u, FillPrice = %f, Quantity = %u", OrderFillData.InternalOrderID, OrderFillData.FillPrice, OrderQuantity); sc.AddMessageToLog(OrderFillMessage, 0); } } } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-01-21 02:22:46] |
Is posible to get in similery way "OrderFillData.InternalOrderID, OrderFillData.FillPrice, OrderQuantity" from other Chart/Symbol in replay mode?
[2019-05-15 18:03:20] |
I have no idea how i get open orderes and status for other Symbol used sc.GetOrderFillArraySize. Without OrderID i do no see way to manage orders in Other Symbol like u manual Automated Trading From an Advanced Custom Study: Submitting and Managing Orders for Different Symbol and/or Trade Account With this Code i pull most infos from s_SCPositionData structure, but not ordersIDs. s_SCPositionData PositionData; sc.GetTradePositionForSymbolAndAccount(PositionData, "F.US.YMM19", sc.SelectedTradeAccount); Is posible to get open OrdersIDs for other Symbols (without Chart)? Date Time Of Last Edit: 2019-05-15 20:44:57
