Date/Time: Thu, 23 Jan 2025 18:16:30 +0000
Chartbook and MDI Tabs Font Style in v1850
View Count: 1050
[2018-12-09 09:48:08] |
ticinotrader - Posts: 400 |
Dear Support, I currently upgraded to the latest 1849, then 1850 versions and I have the following problem: no matter what font type and font size I set at Global Graphics Settings -> Chartbook and MDI Tabs Text, the Chartbook and Chart Tabs' font style automatically reverts back to a different font style. When I re-select the font style/size, the tabs are shown correctly, but then suddenly a different font style is displayed. For example this happens when I switch between chartbooks using the chartbook tabs. Can you please advise how can I fix this? Thank you. |
[2018-12-10 06:50:46] |
The Chartbook and MDI tabs component, is going to get replaced and we are not willing to put any further development into what exists. So we cannot help with this. What exists now is Microsoft based. Also we do not observe what you are describing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-10 16:27:09] |
TechTrader - Posts: 116 |
I am also experiencing the issues described in post#1 I upgraded from SC1842 to SC1849 |
[2018-12-10 19:50:03] |
Okay it is a priority for us to get the new MDI and Chartbook tab functionality out. This is one of the next items we are working on.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-10 19:50:18
