Date/Time: Thu, 23 Jan 2025 18:19:23 +0000
Creating additional sim accounts- where?
View Count: 2280
[2018-12-08 17:30:20] |
User686258 - Posts: 7 |
Hi, I read in a few posts that it is possible to set up additional sim accounts, attached to the same primary account but I cannot see where that is done. I would appreciate being pointed to where on the platform the additional sim accounts are actually created. Thank You. |
[2018-12-08 21:33:23] |
Refer to: Global Trade Settings Windows: Number of Simulation Accounts (Global Settings >> General Trade Settings >> General) If you want to use the Sierra Chart server-side trading evaluator functionality let us know and we can assign you a trading account for that, but that will require using the Sierra Chart Exchange Data Feed which is an additional cost: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
