Date/Time: Sun, 24 Nov 2024 13:56:45 +0000
no mapping for cl
View Count: 1260
[2013-11-06 17:33:55]
workwithus - Posts: 15
receiving mapping for es but not cl.need help.http://www.sierrachart.com/image.php?l=1383759391601.png
http://www.sierrachart.com/image.php?l=1383759421773.png
Date Time Of Last Edit: 2013-11-06 17:37:13
[2013-11-06 18:46:17]
We checked and the mapping is set up for CL for Interactive Brokers.
Could you go to Global Settings >> Symbol Settings. Press the Update From Server button. Wait for the button to reenable and then press OK.
After that select File >> Disconnect and then
File >> Connect to Data Feed.
Date Time Of Last Edit: 2013-11-06 18:47:05
[2013-11-06 19:05:49]
that worked.thanks
