Date/Time: Thu, 23 Jan 2025 18:22:19 +0000
Automated Trading Manager ATM- Response
View Count: 684
[2018-12-07 18:52:32] |
User379557 - Posts: 37 |
Thank you for your quick response. I have reviewed attached orders automated trading and that is not what I was looking for. What I want to do specifically is automatic trading from either the chart or study indicator. A chart example- if using a one minute bar chart if the last bar is positive I want to the trading DOM to automatically go long. If the last bar is negative I want the trading DOM to sell or go short. A study indicator example- if using a momentum study indicator I want the trading DOM to automatically go long if momentum is above zero or automatically go short if momentum is below zero. Can the current ATM do this? If not, can I get a script program to do this? Can you provide this? I appreciate your time. Thanks.
[2018-12-07 19:09:35] |
There is a simple way that Sierra Chart provides to do this and it is with the Trading System Based on Alert Condition study. Refer to: Trading System Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
