Date/Time: Sun, 24 Nov 2024 13:29:02 +0000
User Email Question
View Count: 1322
[2013-11-06 17:32:33] |
Sierra Chart - Max - Posts: 5730 |
1) RJ# as the symbol can pull up the TF continuous chart with a lot of more days. But the supposed real-time price is different from the real-time quote on TFZ3 chart. Could people at Sierra explain why? 2) I need intraday and daily charts for TFM3, but Sierra has March 9 to June 5 missing. Are they going to get them soon? 3) I'd like to draw a "price" line, i.e. a horizontal line connecting two points I click on, showing the price level and without extending left or right. I've been playing with the drawing tools but couldn't find anything like this. Any suggestion? 4) In the daily chart (current month and continuous), the "session time" area in "chart setting" shows default (0:00:00 to 23:59:59) and is deactivated (I can't change it). However, the opening price of the daily bar seems to suggest it actually opens at 19:00:00 and I can't figure out when it closes. I tried to match them with the closing price at 16:59:59 and 23:59:59 on intraday chart, but to no avail. Could you let me know what I did wrong? Also, can I change the session time on daily chart. Sierra's manual suggests it's possible but I can't find instructions. Sierra Chart Support |
[2013-11-07 04:09:03] |
1. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html#Method2 2. Refer to help topic 42.1 here: http://www.sierrachart.com/index.php?l=doc/helpdetails42.html 3. Use the Line drawing tool documented here: http://www.sierrachart.com/index.php?l=doc/doc_Tools.html#LineRay Please be sure to refer to the documentation. 4. Refer to: http://www.sierrachart.com/index.php?l=doc/helpdetails12.html#h12.8 The Session Times cannot be changed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
