Date/Time: Thu, 23 Jan 2025 18:11:11 +0000
A Simple Gap Down Screener Code?
View Count: 1595
[2018-12-07 12:26:50] |
mrfixituk - Posts: 2 |
What is the code to use for a simple gap down screener? All I want to do is screen at the end of the day a specific list of stocks which have gaped down. I was using a couple of charting software packages but I had to type in a few hundred symbols to use it.
[2018-12-07 17:46:51] |
Refer to the documentation here for this: Study/Chart Alerts And Scanning Here is the information for scanning: Study/Chart Alerts And Scanning: Scanning for Alert Condition Across Multiple Symbols You will want to use a Historical Daily chart and write a formula to determine this condition. And here is the documentation to enter the Alert Formula on the main price graph: Study/Chart Alerts And Scanning: To Enter an Alert Condition on the Main Chart/Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-08 12:15:41] |
Thanks. Far too techinical for me. I will stick with Incredible Charts/ Prorealtime and input the symbols manually
