Date/Time: Thu, 23 Jan 2025 18:15:30 +0000
Hot Key working for DOM not working on bar Chart that also displays the Chart DOM
View Count: 709
[2018-12-07 07:22:51]
User153286 - Posts: 49
I created a "flatten and cancel" menu hot key triggered using Cntrl F
I have a DOM opened in it's own detached window. It has the Sell and Buy columns configured to display.
I have a chart opened in it's own detached window
Both windows display the same instrument.
I then configure the chart window to also display the Chart Trading DOM. It too has the Sell and Buy columns configured to display.
I then place an order in either window.
Cntrl F works if the DOM detached window has focus.
Cntrl F does not work if the Chart window has focus.
build 1842 64-bit(25240:25241M)
Date Time Of Last Edit: 2018-12-07 07:31:06
[2018-12-07 18:22:07]
Make sure you have enabled the keyboard shortcuts:
Trade Menu: Trading Keyboard Shortcuts Enabled (Trade menu)
[2018-12-09 23:11:26]
that was the issue, it was not enable for that chart
Trade-> Trading Keyboard Shortcuts Enabled
Date Time Of Last Edit: 2018-12-12 06:23:50
