Date/Time: Sun, 24 Nov 2024 14:23:51 +0000
[User Discussion] - Bollinger squeeze 2 question
View Count: 2828
[2013-11-06 15:35:48] |
Jim - Posts: 31 |
Hello, What is the particular momentum study and settings found as a histogram used in the default Bollinger Squeeze 2 indicator? Thanks in advance for your assistance. Jim |
[2013-11-06 18:34:05] |
vegasfoster - Posts: 444 |
The formula is N period EMA of the current close minus the close from N bars ago or EMA((Close[0] - Close[0-N], N) But I'm not aware of another indicator that uses the exact same formula. |
[2013-11-06 18:58:34] |
Jim - Posts: 31 |
What is the Momentum study that uses this formula? When I look at the settings and inputs of the bollinger band squeeze 2 indicator all that is listed is "momentum." I would like just this particular momentum study. Thanks. |
[2013-11-06 19:00:50] |
Jim - Posts: 31 |
Sorry vegasfoster, missed your last sentence. Does anyone elso know?? Thanks. |
[2013-11-06 19:00:51] |
M5amhan - Posts: 468 |
you can just set everything you dont want to use to ignore
[2013-11-06 19:07:04] |
Jim - Posts: 31 |
Thanks. I just wanted to know what this particular momentum study was and if there was a stand alone version.
[2013-11-06 19:08:57] |
I can make one easy enough if you want.
[2013-11-06 19:19:33] |
Jim - Posts: 31 |
I would really appreciate that.
[2013-11-08 17:17:40] |
Stripped down to momo only. Let me know if you have any issues.
[2013-11-08 20:22:09] |
Jim - Posts: 31 |
Where can i find this? Thanks
[2013-11-08 21:22:57] |
Hmmm, very good question! :)
[2013-11-08 21:23:34] |
I'm attaching but they aren't uploading for reasons I don't know.
[2013-11-08 21:24:16] |
Try again
[2013-11-08 21:25:17] |
And again
[2013-11-08 21:26:26] |
When I preview it shows they are attached but when I post they are gone. I'm gonna start another thread called Bollinger Squeeze Only and try it again.
[2013-11-08 21:28:37] |
Go here Bollinger Squeeze Momo | Post: 16530
[2013-11-12 10:13:54] |
Jim - Posts: 31 |
Thank you vegas, I really appreciate your help. For some reason I cant get this to work. As per SC instructions, I am saving the file from the forum then moving the .dll file to my data folder. Then I am opening analysis menu on the top and I dont see the study. Am I doing something wrong? Thanks again.
[2013-11-12 11:53:30] |
Jim - Posts: 31 |
Duh, forgot to update charts to new version. It works. Thanks again Vegas.
