Date/Time: Thu, 23 Jan 2025 18:30:36 +0000
New to Sierra
View Count: 1440
[2018-12-07 00:25:12] |
User504204 - Posts: 3 |
I use CQG data with Ninja trader and Dorman brokerage. Would I be able to still use those and just link them to Sierra? Could I use the same data with Sierra and Ninja both and continue to trade with Ninja? I'm looking at Sierra because it has options that NT doesn't. Thanks
Date Time Of Last Edit: 2018-12-07 00:25:30
[2018-12-07 19:08:09] |
This could be a problem because we do not think CQG is going to allow two simultaneous connections. Have a look at the Sierra Chart trading functionality. It is quite good. You can get started here: Overview of Trading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-07 19:08:25
[2018-12-08 00:52:04] |
Xfanman1 - Posts: 320 |
Check with CQG first, last time I checked (but it’s been awhile) I believe they would allow another connection to your account for $10-$15/mth. — Scott |
