Date/Time: Thu, 23 Jan 2025 18:27:19 +0000
Volume by Price study set to 1 Bar for each profile and combined with the Numbers Bars stu
View Count: 1773
[2018-12-06 16:10:31] |
User564400 - Posts: 4 |
Hello, i would like to create the same chart found here (named same like the Title of my post) Volume By Price Study but i can not figure out how to do it. Would be awesome and i would really appreciate it if somebody can helo me out. Thanks in advance Best Regars Chris |
Unbenannt.PNG / V - Attached On 2018-12-06 16:07:07 UTC - Size: 76.1 KB - 602 views Attachment Deleted. |
[2018-12-06 17:39:42] |
User907968 - Posts: 825 |
You can use number bars with 'Background Type' set to 'Volume Profile' - see link below Numbers Bars: Numbers Bars Background Types "Volume Profile: This background type fills the background for a price level based upon the volume at the price level compared to the maximum volume among all of the price levels within the Numbers Bar." or You could use the VBP study and set the 'Volume Graph Period Type' to 'Multiple Profiles Based on Bar Count' and then set 'Number of Bars for Based on Bar Count' to 1 - see link Volume By Price Study: Multiple Profiles Based on Bar Count Hopefully this is what you are looking for. |
[2018-12-07 17:19:27] |
John - SC Support - Posts: 37437 |
As the User above has noted, those are the ways to do this. Some additional documentation for when you are using the Numbers Bars along with the Volume by Price study can be found here for how to setup the Volume by Price study for each bar: Volume By Price Study: One Volume Profile per Chart Bar For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
