Date/Time: Thu, 23 Jan 2025 18:19:54 +0000
Logging Trade Activity Log permanently to disk
View Count: 575
[2018-12-06 13:29:18]
User528369 - Posts: 5
Hello Support,
is there a possibility to write the Logging Trade Activity Log permanently to disk in to a file as soon as a trade is done?
Or is the only way to do this manuall by File >> Save log as?
Or is there any other possibiliy to see which position is currently traded in any kind of log file?
Kind Regards
Adrian Buechner
[2018-12-06 17:43:12]
This is already the case but make sure you are running the current version:
Or are you referring to logging also to a plain text file?
Refer to:
Trade Activity Log: Determining Historical Trade Position Quantity from Trade Activity Log
[2018-12-06 18:07:30]
Thanks for your quick answer. Yes I just updated to the newest Version but logging in to a plain text file is still not possible.
Yes I would like to habe each trade that is done automaticaly into a plain text file.
Regards
Adrian Buechner
[2018-12-06 18:36:54]
Okay this is not supported.
