Date/Time: Thu, 23 Jan 2025 18:10:59 +0000
User-selected drawing
View Count: 587
[2018-12-05 21:17:36] |
User710890 - Posts: 23 |
I am trying to access the currently selected user drawing on a given chart via ACSIL (I just need the line number of whatever is currently selected). I have looked through the documentation and see no reference to this specifically. Am I missing something here? Not sure if I am missing something in the documentation or that it simply doesn't exist, but I don't get why something like this which you'd expect to be easily accessible, would be completely inaccessible. Thank you in advance. |
[2018-12-05 23:00:12] |
This is not supported but we will see about adding a function to get the Line Number of the selected drawing.
