Date/Time: Sun, 24 Nov 2024 13:34:27 +0000
Symbol Setup needed on RT Feed
View Count: 1393
[2013-11-06 14:28:10]
TI Anon - Posts: 36
Please setup- YM-201312-CBOT for TTFix on CME realtime feed.
[2013-11-06 16:02:14]
We will set this up in the next 10 minutes.
[2013-11-06 16:12:03]
This is now done. Here is an example chart:
http://www.sierrachart.com/image.php?l=1383754241314.png
You will need to restart Sierra Chart for this to go into effect.
Or you could go to Global Settings >> Symbol Settings and press the Update From Server button. Wait for the button to reenable and press OK. After that reconnect to the data feed with the commands on the File menu.
Date Time Of Last Edit: 2013-11-06 16:12:35
[2013-11-06 16:26:23]
TI Anon - Posts: 36
"Requested Market Depth" on Data/Trade Service Settings window is now not functional. Full Book is shown on chart regardless of setting.
v1041
Date Time Of Last Edit: 2013-11-06 16:27:26
[2013-11-06 16:33:19]
Yes, this is true. There is no way to control the number of levels. You will always get the full book because the efficiency of this data feed.
