Date/Time: Thu, 23 Jan 2025 18:28:19 +0000
Volume By Price custom color by Ask - Bid
View Count: 1386
[2018-12-05 18:03:11] |
User564250 - Posts: 8 |
Hi Support, I'm trying to color each price of the volume by price indicator by a percentage of the max(abs(Ask - Bid)) of the entire profile where values of Ask - Bid > 0 are a shade of green and values Ask - Bid < 0 are a shade of red. Is there a way to access the coloring of this indicator through ACSIL? |
[2018-12-05 23:04:08] |
No, there is not a way to access the coloring.
[2018-12-07 02:47:28] |
I have a number bars study on my chart and a volume by price study on the chart. It appears like the sc.VolumeAtPriceForBars is using the number bars study to pull data from, not the volume by price study. How do I access the data from the volume by price from sc.VolumeAtPriceForBars?
Annotation 2018-12-06 184510.jpg / V - Attached On 2018-12-07 02:46:53 UTC - Size: 162.94 KB - 337 views Attachment Deleted. |
[2018-12-07 18:32:01] |
If you want to access data from a Volume by Price study on the on the chart you need to use this particular function: sc.GetVolumeAtPriceDataForStudyProfile() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
