Date/Time: Fri, 24 Jan 2025 03:42:24 +0000
Where to see chart drawing alerts?
View Count: 1030
[2018-12-05 16:40:09]
skelcap - Posts: 139
Hi, I am following the instructions here to add chart drawing alerts:
Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line
When the alert is activated I see it in the Alerts Log of the Alert Manager. But where can I see all chart drawing alerts listed BEFORE they are activated? I don't see them in the Symbols Log of the Alert Manager, but maybe there is another place, if not can you please add that feature?
[2018-12-05 21:02:19]
For Chart Drawings, you can open the Manage Chart Drawings Window and see which drawings have alerts set on them. Refer to the following documentation for how to access the Manage Chart Drawings Window.
Chart Drawing Tools: Manage Chart Drawings
Date Time Of Last Edit: 2018-12-31 21:11:19
[2018-12-06 02:34:28]
Ok I see that you can dig into each chart drawing and check it has an alert that way, but it's still quite laborious. I was hoping to see a simple list of chart drawing alerts just like you can see all symbol alerts in the alert manager.
[2018-12-31 13:36:26]
Kinobe - Posts: 86
totally agree.
SC is great but for symbol Alert is very laborious.
I d like to see automatically a line on graph when a Symbol Alert is set....it would help a lot.
[2018-12-31 21:10:45]
At the top of the Manage Chart Drawings window, there is a list box and from there you can select "Alerts" to see only the drawings that contain alerts. And then you can select the drawing and press the Alert button to see the details.
Why not just use a horizontal line drawing and set an alert on that?
[2018-12-31 21:35:49]
Kinobe - Posts: 86
because with horizotal line containing an alert, the chart which contains the horizontal line needs to be open. Right?
I can have over 50 stocks to follow...so it will messy quite fast.
