Date/Time: Thu, 23 Jan 2025 18:23:10 +0000
Technical indicator(KDJ)
View Count: 2073
[2018-12-05 15:26:13] |
seven0907 - Posts: 34 |
Hi, SC Could you add in KDJ indicator in sierra chart? thanks. BTW, SC link to IB(TWS), the stock price is not moving until change the time frame. |
[2018-12-05 23:06:41] |
We will look into that study. In regards to the chart updating issue, refer to: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart: 3.4 - Not Receiving Real-Time Data From Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-06 08:35:00] |
The KDJ study is related to the stochastic studies so we will add this particular specific implementation. It will be out in the next release.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-06 08:35:09
[2018-12-07 13:37:25] |
Hi, SC For IB stock like (QQQ, IBM, IWM) I have updated symbol names follow by webside but the price still not moving. IBM: IBM-STK-SMART QQQ: QQQ-STK-SMART IWM: IWM-STK-SMART |
[2018-12-07 18:06:52] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Reconnect to the data feed: File Menu: Procedure to Reconnect to the Data and Trade Servers After about 30 seconds, provide a copy of the Message Log following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-10 14:36:29] |
Hi, SC Pls review it, stock symbol like ASHR, MHCI did not moving. Software version: 1849 64-bit | 2018-12-10 09:32:31 Usage end date: 2019-11-29 | 2018-12-10 09:32:31 Enabled for: Advanced Features. | 2018-12-10 09:32:31 Enabled for: Advanced Features 2. | 2018-12-10 09:32:31 Enabled for: Sierra Chart Historical Data Service. | 2018-12-10 09:32:31 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-12-10 09:32:31 Current selected Data/Trading service: Interactive Brokers | 2018-12-10 09:32:31 Chart Update Interval: 250 | 2018-12-10 09:32:31 Time Zone: -05:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-12-10 09:32:31 2018-12-10 22:32:30 Local computer time | 2018-12-10 09:32:31 2018-12-10 14:32:30 Local computer time in UTC | 2018-12-10 09:32:31 2018-12-10 09:32:30 Local computer time in SC Time Zone | 2018-12-10 09:32:31 2018-12-10 13:48:06 Server time in UTC | 2018-12-10 09:32:31 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-12-10 09:32:31 Program path: C:\SierraChart\ | 2018-12-10 09:32:31 Data Files path: C:\SierraChart\Data\ | 2018-12-10 09:32:31 OS Version Number: 10.0 | 2018-12-10 09:32:31 Locale Setting: C | 2018-12-10 09:32:31 DLLs: UserContributedStudies.dll, UserContributedStudies_64.dll | 2018-12-10 09:32:31 File >> Disconnect selected. | 2018-12-10 09:32:48 Socket (3) | Signaling to core to close socket | 2018-12-10 09:32:48 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:32:48 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:32:48 Socket (3) | Closed. | 2018-12-10 09:32:48 DTC Client socket (5) | Signaling to core to close socket | 2018-12-10 09:32:48 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:32:48 SC DTC Data with Market Depth | Disconnected from the server. | 2018-12-10 09:32:48 Interactive Brokers | Disconnected. | 2018-12-10 09:32:48 DTC Client socket (5) | Socket gracefully closed by remote side. | 2018-12-10 09:32:48 DTC Client socket (5) | Closed. | 2018-12-10 09:32:48 Interactive Brokers | Connecting to 127.0.0.1:4001 | 2018-12-10 09:32:51 Starting TWS auto-login thread. | 2018-12-10 09:32:51 Socket (1) | Creating socket. | 2018-12-10 09:32:51 Socket (1) | Connecting to IP: 127.0.0.1. | 2018-12-10 09:32:51 TWS auto-login thread ending. | 2018-12-10 09:32:51 Interactive Brokers | Sending API sign: API | 2018-12-10 09:32:51 Interactive Brokers | Sending client version: v100..136 +PACEAPI. Waiting for acceptance. | 2018-12-10 09:32:51 Interactive Brokers | TWS server version: 136 | 2018-12-10 09:32:51 Interactive Brokers | TWS time: 20181210 09:32:50 EST | 2018-12-10 09:32:51 Interactive Brokers | Connected. Sending Start API command. | 2018-12-10 09:32:51 Interactive Brokers | Waiting for account information. | 2018-12-10 09:32:51 IB Account information received. | 2018-12-10 09:32:51 Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-12-10 09:32:51 Interactive Brokers | Connected to Live account. | 2018-12-10 09:32:51 Interactive Brokers | Year-Month last connected to Live account: 2018-12 | 2018-12-10 09:32:51 Interactive Brokers | Connected to data and trading server. | 2018-12-10 09:32:51 Interactive Brokers | Starting real-time market data updates for: UB-201812-ECBOT-USD. ID: 1 | 2018-12-10 09:32:51 Interactive Brokers | Subscribing to Symbol: UB, SecurityType: FUT, Expiration: 201812, Exchange: ECBOT, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:51 Interactive Brokers | Requesting security definition data for: UB-201812-ECBOT-USD. ID: 1 | 2018-12-10 09:32:51 Intraday data recording state for symbol UB-201812-ECBOT-USD is set to download 'Pending'. | 2018-12-10 09:32:51 ZB-201812-ECBOT [C] 60 Min #1 | Started historical data download for additional symbol UB-201812-ECBOT-USD. Download ID: 60 | 2018-12-10 09:32:51 Interactive Brokers | Starting real-time market data updates for: SI-201812-NYMEX-USD-5000. ID: 2 | 2018-12-10 09:32:51 Interactive Brokers | Subscribing to real-time True Data for symbol: SI SecurityType: FUT Exchange: NYMEX Currency: USD | 2018-12-10 09:32:51 Interactive Brokers | Subscribing to Symbol: SI, SecurityType: FUT, Expiration: 201812, Exchange: NYMEX, Primary Exchange: , Currency: USD, Multiplier: 5000, CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:51 Interactive Brokers | Requesting security definition data for: SI-201812-NYMEX-USD-5000. ID: 2 | 2018-12-10 09:32:51 Intraday data recording state for symbol SI-201812-NYMEX-USD-5000 is set to download 'Pending'. | 2018-12-10 09:32:51 GC-201812-NYMEX [C] 60 Min #2 | Started historical data download for additional symbol SI-201812-NYMEX-USD-5000. Download ID: 61 | 2018-12-10 09:32:51 Interactive Brokers | Starting real-time market data updates for: RTY-201812-GLOBEX-USD. ID: 3 | 2018-12-10 09:32:51 Interactive Brokers | Subscribing to Symbol: RTY, SecurityType: FUT, Expiration: 201812, Exchange: GLOBEX, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:51 Interactive Brokers | Requesting security definition data for: RTY-201812-GLOBEX-USD. ID: 3 | 2018-12-10 09:32:51 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: RTY-201812-GLOBEX-USD | 2018-12-10 09:32:51 Intraday data recording state for symbol RTY-201812-GLOBEX-USD is set to download 'Pending'. | 2018-12-10 09:32:51 NQ-201812-GLOBEX [C] 60 Min #3 | Started historical data download for additional symbol RTY-201812-GLOBEX-USD. Download ID: 62 | 2018-12-10 09:32:51 Interactive Brokers | Starting real-time market data updates for: VIX-20181100-CFE-USD-1000. ID: 4 | 2018-12-10 09:32:51 Interactive Brokers | Subscribing to real-time True Data for symbol: VIX SecurityType: FUT Exchange: CFE Currency: USD | 2018-12-10 09:32:51 Interactive Brokers | Subscribing to Symbol: VIX, SecurityType: FUT, Expiration: 20181100, Exchange: CFE, Primary Exchange: , Currency: USD, Multiplier: 1000, CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:51 Interactive Brokers | Requesting security definition data for: VIX-20181100-CFE-USD-1000. ID: 4 | 2018-12-10 09:32:51 Interactive Brokers | Starting real-time market data updates for: HG-201812-NYMEX. ID: 5 | 2018-12-10 09:32:51 Interactive Brokers | Subscribing to real-time True Data for symbol: HG SecurityType: FUT Exchange: NYMEX Currency: | 2018-12-10 09:32:51 Interactive Brokers | Subscribing to Symbol: HG, SecurityType: FUT, Expiration: 201812, Exchange: NYMEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: HG-201812-NYMEX. ID: 5 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: CL-201812-NYMEX. ID: 6 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: CL SecurityType: FUT Exchange: NYMEX Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: CL, SecurityType: FUT, Expiration: 201812, Exchange: NYMEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: CL-201812-NYMEX. ID: 6 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ES-201812-GLOBEX. ID: 7 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ES SecurityType: FUT Exchange: GLOBEX Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ES, SecurityType: FUT, Expiration: 201812, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ES-201812-GLOBEX. ID: 7 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: GC-201808-NYMEX. ID: 8 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: GC SecurityType: FUT Exchange: NYMEX Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: GC, SecurityType: FUT, Expiration: 201808, Exchange: NYMEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: GC-201808-NYMEX. ID: 8 | 2018-12-10 09:32:52 Intraday data recording state for symbol GC-201808-NYMEX is set to download 'Pending'. | 2018-12-10 09:32:52 HG-201807-NYMEX [C] 60 Min #9 | Started historical data download for additional symbol GC-201808-NYMEX. Download ID: 63 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: $TNX. ID: 9 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: $TNX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: $TNX. ID: 9 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: $TNX | 2018-12-10 09:32:52 Intraday data recording state for symbol $TNX is set to download 'Pending'. | 2018-12-10 09:32:52 HG-201807-NYMEX [C] 60 Min #9 | Started historical data download for additional symbol $TNX. Download ID: 64 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: BZ-201812-NYMEX-USD-1000. ID: 10 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: BZ SecurityType: FUT Exchange: NYMEX Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: BZ, SecurityType: FUT, Expiration: 201812, Exchange: NYMEX, Primary Exchange: , Currency: USD, Multiplier: 1000, CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: BZ-201812-NYMEX-USD-1000. ID: 10 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: IWM-STK-SMART. ID: 11 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: IWM SecurityType: STK Exchange: SMART Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: IWM, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: IWM-STK-SMART. ID: 11 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: XINA50-201811-SGX-USD-1. ID: 12 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: XINA50 SecurityType: FUT Exchange: SGX Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: XINA50, SecurityType: FUT, Expiration: 201811, Exchange: SGX, Primary Exchange: , Currency: USD, Multiplier: 1, CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: XINA50-201811-SGX-USD-1. ID: 12 | 2018-12-10 09:32:52 Interactive Brokers | Using primary service for historical data for XINA50-201811-SGX-USD-1 | 2018-12-10 09:32:52 Intraday data recording state for symbol XINA50-201811-SGX-USD-1 is set to download 'Pending'. | 2018-12-10 09:32:52 XINA50-201812-SGX-USD-1 [C-D] 60 Min #6 | Started historical data download for additional symbol XINA50-201811-SGX-USD-1. Download ID: 65 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ZN-201809-ECBOT. ID: 13 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ZN SecurityType: FUT Exchange: ECBOT Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ZN, SecurityType: FUT, Expiration: 201809, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ZN-201809-ECBOT. ID: 13 | 2018-12-10 09:32:52 Intraday data recording state for symbol ZN-201809-ECBOT is set to download 'Pending'. | 2018-12-10 09:32:52 $TNX [C-D] 60 Min #2 | Started historical data download for additional symbol ZN-201809-ECBOT. Download ID: 66 | 2018-12-10 09:32:52 Next valid order ID: 1 | 2018-12-10 09:32:52 Message from IB: Market data farm connection is OK:hfarm. IB Error Code: 2104. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: Market data farm connection is OK:usfarm.nj. IB Error Code: 2104. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: Market data farm connection is OK:jfarm. IB Error Code: 2104. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: Market data farm connection is OK:usfuture. IB Error Code: 2104. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: Market data farm connection is OK:usopt. IB Error Code: 2104. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: HMDS data farm connection is OK:ushmds.us. IB Error Code: 2106. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: HMDS data farm connection is OK:ilhmds. IB Error Code: 2106. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: HMDS data farm connection is OK:njhmds. IB Error Code: 2106. Request ID: -1. | 2018-12-10 09:32:52 Message from IB: HMDS data farm connection is OK:hkhmds. IB Error Code: 2106. Request ID: -1. | 2018-12-10 09:32:52 Delaying start of download for XINA50-201811-SGX-USD-1 | 2018-12-10 09:32:52 Delaying start of download for UB-201812-ECBOT-USD | 2018-12-10 09:32:52 Next valid order ID: 1 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: DX-201812-NYBOT. ID: 14 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: DX SecurityType: FUT Exchange: NYBOT Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: DX, SecurityType: FUT, Expiration: 201812, Exchange: NYBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: DX-201812-NYBOT. ID: 14 | 2018-12-10 09:32:52 Symbol Error - VIX-20181100-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ZB-201812-ECBOT. ID: 15 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ZB SecurityType: FUT Exchange: ECBOT Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ZB, SecurityType: FUT, Expiration: 201812, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ZB-201812-ECBOT. ID: 15 | 2018-12-10 09:32:52 Intraday data recording state for symbol ZB-201812-ECBOT is set to download 'Pending'. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: MCHI-STK-SMART. ID: 16 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: MCHI SecurityType: STK Exchange: SMART Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: MCHI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: MCHI-STK-SMART. ID: 16 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ZT-201903-ECBOT. ID: 17 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ZT SecurityType: FUT Exchange: ECBOT Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ZT, SecurityType: FUT, Expiration: 201903, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ZT-201903-ECBOT. ID: 17 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZT-201903-ECBOT | 2018-12-10 09:32:52 Intraday data recording state for symbol ZT-201903-ECBOT is set to download 'Pending'. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ZN-201903-ECBOT. ID: 18 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ZN SecurityType: FUT Exchange: ECBOT Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ZN, SecurityType: FUT, Expiration: 201903, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ZN-201903-ECBOT. ID: 18 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZN-201903-ECBOT | 2018-12-10 09:32:52 Intraday data recording state for symbol ZN-201903-ECBOT is set to download 'Pending'. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: $TYX. ID: 19 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: $TYX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: $TYX. ID: 19 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: $TYX | 2018-12-10 09:32:52 Intraday data recording state for symbol $TYX is set to download 'Pending'. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ZB-201903-ECBOT. ID: 20 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ZB SecurityType: FUT Exchange: ECBOT Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ZB, SecurityType: FUT, Expiration: 201903, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ZB-201903-ECBOT. ID: 20 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZB-201903-ECBOT | 2018-12-10 09:32:52 Intraday data recording state for symbol ZB-201903-ECBOT is set to download 'Pending'. | 2018-12-10 09:32:52 Symbol Error - VIX-20181100-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 Symbol Error - VIX-20181100-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: VIX-20190100-CFE-USD-1000. ID: 21 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: VIX SecurityType: FUT Exchange: CFE Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: VIX, SecurityType: FUT, Expiration: 20190100, Exchange: CFE, Primary Exchange: , Currency: USD, Multiplier: 1000, CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: VIX-20190100-CFE-USD-1000. ID: 21 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: XINA50-201812-SGX-USD-1. ID: 22 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: XINA50 SecurityType: FUT Exchange: SGX Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: XINA50, SecurityType: FUT, Expiration: 201812, Exchange: SGX, Primary Exchange: , Currency: USD, Multiplier: 1, CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: XINA50-201812-SGX-USD-1. ID: 22 | 2018-12-10 09:32:52 Interactive Brokers | Using primary service for historical data for XINA50-201812-SGX-USD-1 | 2018-12-10 09:32:52 Intraday data recording state for symbol XINA50-201812-SGX-USD-1 is set to download 'Pending'. | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Starting real-time market data updates for: nisS-NYSE. ID: 23 | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 443 | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Requesting security definition data for: nisS-NYSE. ID: 23 | 2018-12-10 09:32:52 Intraday data recording state for symbol nisS-NYSE is set to download 'Pending'. | 2018-12-10 09:32:52 DTC Client socket (2) | Creating socket. | 2018-12-10 09:32:52 DTC Client socket (2) | Connecting to IP: 65.182.172.42. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ASHR-STK-SMART. ID: 24 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ASHR SecurityType: STK Exchange: SMART Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ASHR, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ASHR-STK-SMART. ID: 24 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ASHR-STK-SMART | 2018-12-10 09:32:52 Intraday data recording state for symbol ASHR-STK-SMART is set to download 'Pending'. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: HG-201807-NYMEX. ID: 25 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: HG SecurityType: FUT Exchange: NYMEX Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: HG, SecurityType: FUT, Expiration: 201807, Exchange: NYMEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: HG-201807-NYMEX. ID: 25 | 2018-12-10 09:32:52 Intraday data recording state for symbol HG-201807-NYMEX is set to download 'Pending'. | 2018-12-10 09:32:52 Symbol Error - CL-201812-NYMEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - CL-201812-NYMEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: VIX-20181200-CFE-USD-1000. ID: 26 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: VIX SecurityType: FUT Exchange: CFE Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: VIX, SecurityType: FUT, Expiration: 20181200, Exchange: CFE, Primary Exchange: , Currency: USD, Multiplier: 1000, CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: VIX-20181200-CFE-USD-1000. ID: 26 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: FXI-STK-SMART. ID: 27 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: FXI SecurityType: STK Exchange: SMART Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: FXI, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: FXI-STK-SMART. ID: 27 | 2018-12-10 09:32:52 Symbol Error - GC-201808-NYMEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - GC-201808-NYMEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - $TNX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - $TNX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - BZ-201812-NYMEX-USD-1000 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - BZ-201812-NYMEX-USD-1000 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - XINA50-201811-SGX-USD-1 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - XINA50-201811-SGX-USD-1 is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - ZN-201809-ECBOT is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - ZN-201809-ECBOT is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - VIX-20190100-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 Symbol Error - VIX-20190100-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 Symbol Error - $TYX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - VIX-20190100-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: QQQ-STK-SMART. ID: 28 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: QQQ SecurityType: STK Exchange: SMART Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: QQQ, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: QQQ-STK-SMART. ID: 28 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: KWEB-STK-SMART. ID: 29 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: KWEB SecurityType: STK Exchange: SMART Currency: USD | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: KWEB, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: KWEB-STK-SMART. ID: 29 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: NQ-201812-GLOBEX. ID: 30 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: NQ SecurityType: FUT Exchange: GLOBEX Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: NQ, SecurityType: FUT, Expiration: 201812, Exchange: GLOBEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: NQ-201812-GLOBEX. ID: 30 | 2018-12-10 09:32:52 Symbol Error - ASHR-STK-SMART is unknown, unavailable, or improperly formatted. The contract description specified for ASHR is ambiguous. | 2018-12-10 09:32:52 Symbol Error - ASHR-STK-SMART is unknown, unavailable, or improperly formatted. The contract description specified for ASHR is ambiguous. | 2018-12-10 09:32:52 Symbol Error - $TYX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - HG-201807-NYMEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - HG-201807-NYMEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - VIX-20181200-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 Symbol Error - VIX-20181200-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 Symbol Error - VIX-20181200-CFE-USD-1000 is unknown, unavailable, or improperly formatted. Invalid value in field # 541 | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Starting real-time market data updates for: NISS-TF. ID: 31 | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Requesting security definition data for: NISS-TF. ID: 31 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: $FVX. ID: 32 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: $FVX, SecurityType: STK, Expiration: , Exchange: SMART, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: $FVX. ID: 32 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: $FVX | 2018-12-10 09:32:52 Intraday data recording state for symbol $FVX is set to download 'Pending'. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ZF-201903-ECBOT. ID: 33 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ZF SecurityType: FUT Exchange: ECBOT Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ZF, SecurityType: FUT, Expiration: 201903, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ZF-201903-ECBOT. ID: 33 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: ZF-201903-ECBOT | 2018-12-10 09:32:52 Intraday data recording state for symbol ZF-201903-ECBOT is set to download 'Pending'. | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for XINA50-201812-SGX-USD-1 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: UB-201903-ECBOT-USD. ID: 34 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: UB, SecurityType: FUT, Expiration: 201903, Exchange: ECBOT, Primary Exchange: , Currency: USD, Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: UB-201903-ECBOT-USD. ID: 34 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: UB-201903-ECBOT-USD | 2018-12-10 09:32:52 Intraday data recording state for symbol UB-201903-ECBOT-USD is set to download 'Pending'. | 2018-12-10 09:32:52 Symbol Error - KWEB-STK-SMART is unknown, unavailable, or improperly formatted. The contract description specified for KWEB is ambiguous. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: ZS-201811-ECBOT. ID: 35 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: ZS SecurityType: FUT Exchange: ECBOT Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: ZS, SecurityType: FUT, Expiration: 201811, Exchange: ECBOT, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: ZS-201811-ECBOT. ID: 35 | 2018-12-10 09:32:52 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQ-201812-GLOBEX | 2018-12-10 09:32:52 Intraday data recording state for symbol NQ-201812-GLOBEX is set to download 'Pending'. | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: GC-201812-NYMEX. ID: 36 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: GC SecurityType: FUT Exchange: NYMEX Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: GC, SecurityType: FUT, Expiration: 201812, Exchange: NYMEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: GC-201812-NYMEX. ID: 36 | 2018-12-10 09:32:52 Intraday data recording state for symbol GC-201812-NYMEX is set to download 'Pending'. | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Starting real-time market data updates for: DTIS-NYSE. ID: 37 | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Requesting security definition data for: DTIS-NYSE. ID: 37 | 2018-12-10 09:32:52 Interactive Brokers | Starting real-time market data updates for: NG-201812-NYMEX. ID: 38 | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to real-time True Data for symbol: NG SecurityType: FUT Exchange: NYMEX Currency: | 2018-12-10 09:32:52 Interactive Brokers | Subscribing to Symbol: NG, SecurityType: FUT, Expiration: 201812, Exchange: NYMEX, Primary Exchange: , Currency: , Multiplier: , CallPut: , Strike: , LocalSymbol: , TradingClass: | 2018-12-10 09:32:52 Interactive Brokers | Requesting security definition data for: NG-201812-NYMEX. ID: 38 | 2018-12-10 09:32:52 Intraday data recording state for symbol NG-201812-NYMEX is set to download 'Pending'. | 2018-12-10 09:32:52 Symbol Error - KWEB-STK-SMART is unknown, unavailable, or improperly formatted. The contract description specified for KWEB is ambiguous. | 2018-12-10 09:32:52 Symbol Error - $FVX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - $FVX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Starting real-time market data updates for: UTIS-NYSE. ID: 39 | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Requesting security definition data for: UTIS-NYSE. ID: 39 | 2018-12-10 09:32:52 Intraday data recording state for symbol UTIS-NYSE is set to download 'Pending'. | 2018-12-10 09:32:52 HD Request # 58 | Downloading Intraday chart data for XINA50-201811-SGX-USD-1 to the file XINA50-201811-SGX-USD-1.scid. Service: interactive_brokers.trading | 2018-12-10 09:32:52 HD Request # 58 | Download start date-time: 2018-11-29 03:34:30.000 | 2018-12-10 09:32:52 HD Request # 58 | Requesting a total of 1 days and 60329 seconds. | 2018-12-10 09:32:52 HD Request # 58 | IB Backfill - Seconds requested: 86400. Seconds Remaining: 60329. | 2018-12-10 09:32:52 HD Request # 58 | Requesting 1 Day of data at 30 secs with ending date-time at 2018-11-30 03:24:30 for XINA50-201811-SGX-USD-1. PriceType: TRADES | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Connected to server. | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-12-10 09:32:52 Symbol Error - ZS-201811-ECBOT is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - ZS-201811-ECBOT is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - NG-201812-NYMEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Symbol Error - NG-201812-NYMEX is unknown, unavailable, or improperly formatted. No security definition has been found for the request | 2018-12-10 09:32:52 Message from IB: Invalid Real-time Query:No market data permissions for NYBOT FUT. IB Error Code: 420. Request ID: 14. Symbol: DX-201812-NYBOT. | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for UB-201812-ECBOT-USD | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Sending logon request message. | 2018-12-10 09:32:52 HD Request # 58 | Processing historical data message from TWS | 2018-12-10 09:32:52 HD Request # 58 | Receiving Intraday data for XINA50-201811-SGX-USD-1 starting at 2018-11-29 03:25:00 | 2018-12-10 09:32:52 HD Request # 58 | Received 581 records and wrote 0 records from 2018-11-28 22:44:30 to 2018-11-29 03:34:30. | 2018-12-10 09:32:52 HD Request # 58 | IB Backfill - Seconds requested: 60329. Seconds Remaining: 0. | 2018-12-10 09:32:52 HD Request # 58 | Requesting 60329 Seconds of data at 30 secs with ending date-time at 2018-11-30 20:09:59 for XINA50-201811-SGX-USD-1. PriceType: TRADES | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for IWM-STK-SMART | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for MCHI-STK-SMART | 2018-12-10 09:32:52 HD Request # 58 | Message from IB: Historical Market Data Service error message:HMDS query returned no data: CNX18@SGX Trades. IB Error Code: 162. Request ID: 200003. | 2018-12-10 09:32:52 HD Request # 58 | Received 581 records from 2018-11-29 03:25:00 to 2018-11-29 03:34:30 (9.5 minutes) and wrote 0 records for XINA50-201811-SGX-USD-1 | 2018-12-10 09:32:52 HD Request # 58 | Completion time: 1s | 2018-12-10 09:32:52 HD Request # 58 | Intraday data download complete for XINA50-201811-SGX-USD-1. Unique request ID: 65 | 2018-12-10 09:32:52 Removed historical data download ID 65 | 2018-12-10 09:32:52 Real-time Intraday chart data file updates started for XINA50-201811-SGX-USD-1 | 2018-12-10 09:32:52 Intraday chart data file opened for XINA50-201811-SGX-USD-1 | 2018-12-10 09:32:52 XINA50-201812-SGX-USD-1 [C-D] 60 Min #6 | Historical data download for additional symbol XINA50-201811-SGX-USD-1 with ID 65 has completed. | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for SI-201812-NYMEX-USD-5000 | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for RTY-201812-GLOBEX-USD | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for HG-201812-NYMEX | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for ES-201812-GLOBEX | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for ZB-201812-ECBOT | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for ZT-201903-ECBOT | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for ZN-201903-ECBOT | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for ZB-201903-ECBOT | 2018-12-10 09:32:52 Delaying start of download for XINA50-201812-SGX-USD-1 | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for NQ-201812-GLOBEX | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for ZF-201903-ECBOT | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for UB-201903-ECBOT-USD | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for GC-201812-NYMEX | 2018-12-10 09:32:52 XINA50-201812-SGX-USD-1 [C-D] 60 Min #6 | Reloading chart. | 2018-12-10 09:32:52 XINA50-201812-SGX-USD-1 [C-D] 60 Min #6 | Date based rollover rule not defined for symbol. Unable to build continuous futures contract chart. | 2018-12-10 09:32:52 XINA50-201812-SGX-USD-1 [C-D] 60 Min #6 | There are no continuous futures contract symbols. Loading data normally. | 2018-12-10 09:32:52 + Loading additional symbol data. | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for FXI-STK-SMART | 2018-12-10 09:32:52 Interactive Brokers | Market data type is Live for QQQ-STK-SMART | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Received logon response. | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Successfully connected. | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Trading is not supported. | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DTIS-NYSE | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: nisS-NYSE | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NISS-TF | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: UTIS-NYSE | 2018-12-10 09:32:52 SC DTC Data with Market Depth | Received security definition for symbol DTIS-NYSE | 2018-12-10 09:32:53 SC DTC Data with Market Depth | Received security definition for symbol nisS-NYSE | 2018-12-10 09:32:53 SC DTC Data with Market Depth | Received security definition for symbol NISS-TF | 2018-12-10 09:32:53 SC DTC Data with Market Depth | Received security definition for symbol UTIS-NYSE | 2018-12-10 09:32:53 Message from IB: Market data farm connection is OK:usfuture.nj. IB Error Code: 2104. Request ID: -1. | 2018-12-10 09:32:53 Interactive Brokers | Market data type is Delayed for DX-201812-NYBOT | 2018-12-10 09:32:54 Message from IB: Requested market data is not subscribed. Displaying delayed market data... IB Error Code: 10167. Request ID: 14. Symbol: DX-201812-NYBOT. | 2018-12-10 09:32:54 Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates (6)) for account: U918* | 2018-12-10 09:32:56 Interactive Brokers | Received Trade Positions download end message for account U918* | 2018-12-10 09:32:56 HD Request # 59 | Downloading Intraday chart data for XINA50-201812-SGX-USD-1 to the file XINA50-201812-SGX-USD-1.scid. Service: interactive_brokers.trading | 2018-12-10 09:32:57 HD Request # 59 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:32:57 HD Request # 59 | Requesting a total of 0 days and 4816 seconds. | 2018-12-10 09:32:57 HD Request # 59 | IB Backfill - Seconds requested: 4816. Seconds Remaining: 0. | 2018-12-10 09:32:57 HD Request # 59 | Requesting 4816 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:42:56 for XINA50-201812-SGX-USD-1. PriceType: TRADES | 2018-12-10 09:32:57 HD Request # 59 | Processing historical data message from TWS | 2018-12-10 09:32:57 HD Request # 59 | Receiving Intraday data for XINA50-201812-SGX-USD-1 starting at 2018-12-10 09:23:00 | 2018-12-10 09:32:57 HD Request # 59 | Received 21 records and wrote 0 records from 2018-12-10 09:22:30 to 2018-12-10 09:32:30. | 2018-12-10 09:32:57 HD Request # 59 | Received 21 records from 2018-12-10 09:23:00 to 2018-12-10 09:32:30 (9.5 minutes) and wrote 0 records for XINA50-201812-SGX-USD-1 | 2018-12-10 09:32:57 HD Request # 59 | Completion time: 0s | 2018-12-10 09:32:57 HD Request # 59 | Intraday data download complete for XINA50-201812-SGX-USD-1. Unique request ID: 72 | 2018-12-10 09:32:57 Removed historical data download ID 72 | 2018-12-10 09:32:57 Real-time Intraday chart data file updates started for XINA50-201812-SGX-USD-1 | 2018-12-10 09:32:57 Intraday chart data file opened for XINA50-201812-SGX-USD-1 | 2018-12-10 09:32:57 HD Request # 60 | Downloading Intraday chart data for UB-201812-ECBOT-USD to the file UB-201812-ECBOT-USD.scid. Service: cbot | 2018-12-10 09:32:58 HD Request # 60 | Download start date-time: 2018-12-10 09:26:13.000 | 2018-12-10 09:32:58 HD Request # 60 | Using server: ds7.sierracharts.com port 10149 | 2018-12-10 09:32:58 Socket (3) | Creating socket. | 2018-12-10 09:32:58 Socket (3) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:32:58 HD Request # 60 | Setting DTC encoding to Binary VLS | 2018-12-10 09:32:58 HD Request # 60 | Sending historical data logon request message. | 2018-12-10 09:32:58 HD Request # 60 | Requesting Intraday data. Start date-time: 2018-12-10 09:26:13. Record interval: 0. Symbol: UBZ18 | 2018-12-10 09:32:58 HD Request # 60 | Decompressing data. | 2018-12-10 09:32:59 HD Request # 60 | Receiving Intraday data for UB-201812-ECBOT-USD starting at 2018-12-10 08:00:23 | 2018-12-10 09:32:59 Socket (3) | Signaling to core to close socket | 2018-12-10 09:32:59 Historical data download thread signaled to stop. | 2018-12-10 09:32:59 HD Request # 60 | Received 10 records from 2018-12-10 08:00:23 to 2018-12-10 08:48:43 (48.3 minutes) and wrote 0 records for UB-201812-ECBOT-USD | 2018-12-10 09:32:59 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:32:59 HD Request # 60 | Completion time: 1s | 2018-12-10 09:32:59 HD Request # 60 | Intraday data download complete for UB-201812-ECBOT-USD. Unique request ID: 60 | 2018-12-10 09:32:59 Removed historical data download ID 60 | 2018-12-10 09:32:59 Real-time Intraday chart data file updates started for UB-201812-ECBOT-USD | 2018-12-10 09:32:59 Intraday chart data file opened for UB-201812-ECBOT-USD | 2018-12-10 09:32:59 ZB-201812-ECBOT [C] 60 Min #1 | Historical data download for additional symbol UB-201812-ECBOT-USD with ID 60 has completed. | 2018-12-10 09:32:59 HD Request # 61 | Downloading Intraday chart data for SI-201812-NYMEX-USD-5000 to the file SI-201812-NYMEX-USD-5000.scid. Service: comex | 2018-12-10 09:32:59 HD Request # 61 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:32:59 HD Request # 61 | Using server: ds1.sierracharts.com port 10150 | 2018-12-10 09:32:59 Socket (4) | Creating socket. | 2018-12-10 09:32:59 Socket (4) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:32:59 ZB-201812-ECBOT [C] 60 Min #1 | Reloading chart. | 2018-12-10 09:32:59 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:32:59 Socket (3) | Closed. | 2018-12-10 09:32:59 HD Request # 61 | Setting DTC encoding to Binary VLS | 2018-12-10 09:32:59 HD Request # 61 | Sending historical data logon request message. | 2018-12-10 09:32:59 HD Request # 61 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:40. Record interval: 0. Symbol: SIZ18 | 2018-12-10 09:32:59 HD Request # 61 | Decompressing data. | 2018-12-10 09:33:00 HD Request # 61 | Receiving Intraday data for SI-201812-NYMEX-USD-5000 starting at 2018-12-10 07:23:59 | 2018-12-10 09:33:00 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:00 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:00 Historical data download thread signaled to stop. | 2018-12-10 09:33:00 HD Request # 61 | Received 2 records from 2018-12-10 07:23:59 to 2018-12-10 07:30:18 (6.3 minutes) and wrote 0 records for SI-201812-NYMEX-USD-5000 | 2018-12-10 09:33:00 HD Request # 61 | Completion time: 0s | 2018-12-10 09:33:00 HD Request # 61 | Intraday data download complete for SI-201812-NYMEX-USD-5000. Unique request ID: 61 | 2018-12-10 09:33:00 Removed historical data download ID 61 | 2018-12-10 09:33:00 Real-time Intraday chart data file updates started for SI-201812-NYMEX-USD-5000 | 2018-12-10 09:33:00 Intraday chart data file opened for SI-201812-NYMEX-USD-5000 | 2018-12-10 09:33:00 GC-201812-NYMEX [C] 60 Min #2 | Historical data download for additional symbol SI-201812-NYMEX-USD-5000 with ID 61 has completed. | 2018-12-10 09:33:00 HD Request # 62 | Downloading Intraday chart data for RTY-201812-GLOBEX-USD to the file RTY-201812-GLOBEX-USD.scid. Service: cme | 2018-12-10 09:33:00 HD Request # 62 | Download start date-time: 2018-12-10 09:32:47.000 | 2018-12-10 09:33:00 HD Request # 62 | Using server: ds7.sierracharts.com port 10149 | 2018-12-10 09:33:00 Socket (3) | Creating socket. | 2018-12-10 09:33:00 Socket (3) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:00 GC-201812-NYMEX [C] 60 Min #2 | Reloading chart. | 2018-12-10 09:33:00 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:00 Socket (4) | Closed. | 2018-12-10 09:33:00 HD Request # 62 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:00 HD Request # 62 | Sending historical data logon request message. | 2018-12-10 09:33:00 HD Request # 62 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:47. Record interval: 0. Symbol: RTYZ18 | 2018-12-10 09:33:00 HD Request # 62 | Decompressing data. | 2018-12-10 09:33:01 Socket (3) | Signaling to core to close socket | 2018-12-10 09:33:01 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:01 Historical data download thread signaled to stop. | 2018-12-10 09:33:01 HD Request # 62 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for RTY-201812-GLOBEX-USD | 2018-12-10 09:33:01 HD Request # 62 | Completion time: 0s | 2018-12-10 09:33:01 HD Request # 62 | Intraday data download complete for RTY-201812-GLOBEX-USD. Unique request ID: 62 | 2018-12-10 09:33:01 Removed historical data download ID 62 | 2018-12-10 09:33:01 Real-time Intraday chart data file updates started for RTY-201812-GLOBEX-USD | 2018-12-10 09:33:01 Intraday chart data file opened for RTY-201812-GLOBEX-USD | 2018-12-10 09:33:01 NQ-201812-GLOBEX [C] 60 Min #3 | Historical data download for additional symbol RTY-201812-GLOBEX-USD with ID 62 has completed. | 2018-12-10 09:33:01 Interactive Brokers | Using primary service for historical data for RTY-201812-GLOBEX-USD | 2018-12-10 09:33:01 Intraday data recording state for symbol RTY-201812-GLOBEX-USD is set to download 'Pending'. | 2018-12-10 09:33:01 HD Request # 63 | Downloading Intraday chart data for RTY-201812-GLOBEX-USD to the file RTY-201812-GLOBEX-USD.scid. Service: interactive_brokers.trading | 2018-12-10 09:33:01 HD Request # 63 | Download start date-time: 2018-12-10 09:32:47.000 | 2018-12-10 09:33:01 HD Request # 63 | Requesting a total of 0 days and 4813 seconds. | 2018-12-10 09:33:01 HD Request # 63 | IB Backfill - Seconds requested: 4813. Seconds Remaining: 0. | 2018-12-10 09:33:01 HD Request # 63 | Requesting 4813 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:00 for RTY-201812-GLOBEX-USD. PriceType: TRADES | 2018-12-10 09:33:01 HD Request # 64 | Downloading Intraday chart data for GC-201808-NYMEX to the file GC-201808-NYMEX.scid. Service: comex | 2018-12-10 09:33:01 HD Request # 64 | Download start date-time: 2018-08-29 13:07:35.000 | 2018-12-10 09:33:01 HD Request # 64 | Using server: ds1.sierracharts.com port 10150 | 2018-12-10 09:33:01 Socket (4) | Creating socket. | 2018-12-10 09:33:01 Socket (4) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:33:01 NQ-201812-GLOBEX [C] 60 Min #3 | Reloading chart. | 2018-12-10 09:33:01 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:33:01 Socket (3) | Closed. | 2018-12-10 09:33:01 HD Request # 64 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:01 HD Request # 64 | Sending historical data logon request message. | 2018-12-10 09:33:01 HD Request # 63 | Processing historical data message from TWS | 2018-12-10 09:33:01 HD Request # 63 | Receiving Intraday data for RTY-201812-GLOBEX-USD starting at 2018-12-10 09:23:00 | 2018-12-10 09:33:01 HD Request # 63 | Received 21 records and wrote 0 records from 2018-12-10 09:22:30 to 2018-12-10 09:32:30. | 2018-12-10 09:33:01 HD Request # 63 | Received 21 records from 2018-12-10 09:23:00 to 2018-12-10 09:32:30 (9.5 minutes) and wrote 0 records for RTY-201812-GLOBEX-USD | 2018-12-10 09:33:01 HD Request # 63 | Completion time: 1s | 2018-12-10 09:33:01 HD Request # 63 | Intraday data download complete for RTY-201812-GLOBEX-USD. Unique request ID: 83 | 2018-12-10 09:33:01 Removed historical data download ID 83 | 2018-12-10 09:33:01 Real-time Intraday chart data file updates started for RTY-201812-GLOBEX-USD | 2018-12-10 09:33:01 Intraday chart data file opened for RTY-201812-GLOBEX-USD | 2018-12-10 09:33:01 HD Request # 64 | Requesting Intraday data. Start date-time: 2018-08-29 13:07:35. Record interval: 0. Symbol: GCQ18 | 2018-12-10 09:33:01 HD Request # 64 | Decompressing data. | 2018-12-10 09:33:02 HD Request # 64 | Receiving Intraday data for GC-201808-NYMEX starting at 2018-08-29 08:40:59 | 2018-12-10 09:33:02 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:02 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:02 Historical data download thread signaled to stop. | 2018-12-10 09:33:02 HD Request # 64 | Received 2 records from 2018-08-29 08:40:59 to 2018-08-29 08:41:13 (14.0 seconds) and wrote 0 records for GC-201808-NYMEX | 2018-12-10 09:33:02 HD Request # 64 | Completion time: 1s | 2018-12-10 09:33:02 HD Request # 64 | Intraday data download complete for GC-201808-NYMEX. Unique request ID: 63 | 2018-12-10 09:33:02 Removed historical data download ID 63 | 2018-12-10 09:33:02 Real-time Intraday chart data file updates started for GC-201808-NYMEX | 2018-12-10 09:33:02 Intraday chart data file opened for GC-201808-NYMEX | 2018-12-10 09:33:02 HG-201807-NYMEX [C] 60 Min #9 | Historical data download for additional symbol GC-201808-NYMEX with ID 63 has completed. | 2018-12-10 09:33:02 HD Request # 65 | Downloading Intraday chart data for $TNX to the file $TNX.scid. Service: cboe.index | 2018-12-10 09:33:02 HD Request # 65 | Download start date-time: 2018-12-10 08:33:56.000 | 2018-12-10 09:33:02 HD Request # 65 | Using server: ds7.sierracharts.com port 10149 | 2018-12-10 09:33:02 Socket (3) | Creating socket. | 2018-12-10 09:33:02 Socket (3) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:02 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:02 Socket (4) | Closed. | 2018-12-10 09:33:02 HD Request # 65 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:02 HD Request # 65 | Sending historical data logon request message. | 2018-12-10 09:33:02 HD Request # 65 | Requesting Intraday data. Start date-time: 2018-12-10 08:33:56. Record interval: 0. Symbol: $TNX | 2018-12-10 09:33:03 Opened cached Intraday file: C:\SierraChart\Data\SI-201812-NYMEX-USD-5000.scid | 2018-12-10 09:33:03 Opened cached Intraday file: C:\SierraChart\Data\RTY-201812-GLOBEX-USD.scid | 2018-12-10 09:33:03 Opened cached Intraday file: C:\SierraChart\Data\XINA50-201812-SGX-USD-1.scid | 2018-12-10 09:33:03 HD Request # 65 | Decompressing data. | 2018-12-10 09:33:03 HD Request # 65 | Receiving Intraday data for $TNX starting at 2018-12-10 08:33:56 | 2018-12-10 09:33:03 HD Request # 65 | Timestamp of first Intraday data file record written: 2018-12-10 08:34:06 | 2018-12-10 09:33:03 Socket (3) | Signaling to core to close socket | 2018-12-10 09:33:03 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:03 Historical data download thread signaled to stop. | 2018-12-10 09:33:03 HD Request # 65 | Received 295 records from 2018-12-10 08:33:56 to 2018-12-10 09:22:56 (49.0 minutes) and wrote 294 records for $TNX | 2018-12-10 09:33:03 HD Request # 65 | Completion time: 0s | 2018-12-10 09:33:03 HD Request # 65 | Intraday data download complete for $TNX. Unique request ID: 64 | 2018-12-10 09:33:03 Removed historical data download ID 64 | 2018-12-10 09:33:03 Real-time Intraday chart data file updates started for $TNX | 2018-12-10 09:33:03 Intraday chart data file opened for $TNX | 2018-12-10 09:33:03 HG-201807-NYMEX [C] 60 Min #9 | Historical data download for additional symbol $TNX with ID 64 has completed. | 2018-12-10 09:33:03 Interactive Brokers | Using primary service for historical data for $TNX | 2018-12-10 09:33:03 Intraday data recording state for symbol $TNX is set to download 'Pending'. | 2018-12-10 09:33:03 HD Request # 66 | Downloading Intraday chart data for $TNX to the file $TNX.scid. Service: cboe.index | 2018-12-10 09:33:03 HD Request # 66 | Download start date-time: 2018-12-10 09:22:56.000 | 2018-12-10 09:33:03 HD Request # 66 | Requesting a total of 0 days and 5406 seconds. | 2018-12-10 09:33:03 HD Request # 66 | IB Backfill - Seconds requested: 5406. Seconds Remaining: 0. | 2018-12-10 09:33:03 HD Request # 66 | Requesting 5406 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:02 for $TNX. PriceType: TRADES | 2018-12-10 09:33:03 HD Request # 67 | Downloading Intraday chart data for ZN-201809-ECBOT to the file ZN-201809-ECBOT.scid. Service: cbot | 2018-12-10 09:33:03 HD Request # 67 | Download start date-time: 2018-09-19 13:00:50.000 | 2018-12-10 09:33:03 HD Request # 67 | Using server: ds1.sierracharts.com port 10150 | 2018-12-10 09:33:03 Socket (4) | Creating socket. | 2018-12-10 09:33:03 Socket (4) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:33:03 HD Request # 66 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200006. | 2018-12-10 09:33:03 HD Request # 66 | Error downloading historical Intraday data for $TNX. The symbol is unknown to the server. | 2018-12-10 09:33:03 HD Request # 66 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TNX | 2018-12-10 09:33:03 HD Request # 66 | Completion time: 0s | 2018-12-10 09:33:03 HD Request # 66 | Intraday data download complete for $TNX. Unique request ID: 84 | 2018-12-10 09:33:03 Removed historical data download ID 84 | 2018-12-10 09:33:03 Real-time Intraday chart data file updates started for $TNX | 2018-12-10 09:33:03 Intraday chart data file opened for $TNX | 2018-12-10 09:33:03 Message from IB: No historical data query found for ticker id:200006. IB Error Code: 366. Request ID: 200006. | 2018-12-10 09:33:03 HG-201807-NYMEX [C] 60 Min #9 | Reloading chart. | 2018-12-10 09:33:03 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:33:03 Socket (3) | Closed. | 2018-12-10 09:33:03 HD Request # 67 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:03 HD Request # 67 | Sending historical data logon request message. | 2018-12-10 09:33:03 HD Request # 67 | Requesting Intraday data. Start date-time: 2018-09-19 13:00:50. Record interval: 0. Symbol: ZNU18 | 2018-12-10 09:33:04 + Loading additional symbol data. | 2018-12-10 09:33:04 HD Request # 67 | Decompressing data. | 2018-12-10 09:33:04 HD Request # 67 | Receiving Intraday data for ZN-201809-ECBOT starting at 2018-09-19 13:00:50 | 2018-12-10 09:33:04 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:04 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:04 Historical data download thread signaled to stop. | 2018-12-10 09:33:04 HD Request # 67 | Received 5 records from 2018-09-19 13:00:50 to 2018-09-19 13:00:50 (0.0 seconds) and wrote 0 records for ZN-201809-ECBOT | 2018-12-10 09:33:04 HD Request # 67 | Completion time: 2s | 2018-12-10 09:33:04 HD Request # 67 | Intraday data download complete for ZN-201809-ECBOT. Unique request ID: 66 | 2018-12-10 09:33:04 Removed historical data download ID 66 | 2018-12-10 09:33:04 Real-time Intraday chart data file updates started for ZN-201809-ECBOT | 2018-12-10 09:33:04 Intraday chart data file opened for ZN-201809-ECBOT | 2018-12-10 09:33:04 $TNX [C-D] 60 Min #2 | Historical data download for additional symbol ZN-201809-ECBOT with ID 66 has completed. | 2018-12-10 09:33:04 HD Request # 68 | Downloading Intraday chart data for ZB-201812-ECBOT to the file ZB-201812-ECBOT.scid. Service: cbot | 2018-12-10 09:33:04 HD Request # 68 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:04 HD Request # 68 | Using server: ds7.sierracharts.com port 10149 | 2018-12-10 09:33:04 Socket (3) | Creating socket. | 2018-12-10 09:33:04 Socket (3) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:04 $TNX [C-D] 60 Min #2 | Reloading chart. | 2018-12-10 09:33:04 $TNX [C-D] 60 Min #2 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2018-12-10 09:33:04 $TNX [C-D] 60 Min #2 | There are no continuous futures contract symbols. Loading data normally. | 2018-12-10 09:33:04 + Loading additional symbol data. | 2018-12-10 09:33:04 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:04 Socket (4) | Closed. | 2018-12-10 09:33:04 HD Request # 68 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:05 HD Request # 68 | Sending historical data logon request message. | 2018-12-10 09:33:05 HD Request # 68 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:40. Record interval: 0. Symbol: ZBZ18 | 2018-12-10 09:33:05 HD Request # 68 | Decompressing data. | 2018-12-10 09:33:05 HD Request # 68 | Receiving Intraday data for ZB-201812-ECBOT starting at 2018-12-10 08:25:58 | 2018-12-10 09:33:05 Socket (3) | Signaling to core to close socket | 2018-12-10 09:33:05 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:05 Historical data download thread signaled to stop. | 2018-12-10 09:33:05 HD Request # 68 | Received 11 records from 2018-12-10 08:25:58 to 2018-12-10 08:40:12 (14.2 minutes) and wrote 0 records for ZB-201812-ECBOT | 2018-12-10 09:33:05 HD Request # 68 | Completion time: 1s | 2018-12-10 09:33:05 HD Request # 68 | Intraday data download complete for ZB-201812-ECBOT. Unique request ID: 67 | 2018-12-10 09:33:05 Removed historical data download ID 67 | 2018-12-10 09:33:05 Real-time Intraday chart data file updates started for ZB-201812-ECBOT | 2018-12-10 09:33:05 Intraday chart data file opened for ZB-201812-ECBOT | 2018-12-10 09:33:05 HD Request # 69 | Downloading Intraday chart data for ZT-201903-ECBOT to the file ZT-201903-ECBOT.scid. Service: cbot | 2018-12-10 09:33:05 HD Request # 69 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:05 HD Request # 69 | Using server: ds1.sierracharts.com port 10150 | 2018-12-10 09:33:05 Socket (4) | Creating socket. | 2018-12-10 09:33:05 Socket (4) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:33:05 + Loading additional symbol data. | 2018-12-10 09:33:05 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:33:05 Socket (3) | Closed. | 2018-12-10 09:33:05 HD Request # 69 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:06 HD Request # 69 | Sending historical data logon request message. | 2018-12-10 09:33:06 HD Request # 69 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:40. Record interval: 0. Symbol: ZTH19 | 2018-12-10 09:33:06 HD Request # 69 | Decompressing data. | 2018-12-10 09:33:06 + Loading additional symbol data. | 2018-12-10 09:33:06 HD Request # 69 | Receiving Intraday data for ZT-201903-ECBOT starting at 2018-12-10 08:32:35 | 2018-12-10 09:33:07 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:07 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:07 Historical data download thread signaled to stop. | 2018-12-10 09:33:07 HD Request # 69 | Received 7424 records from 2018-12-10 08:32:35 to 2018-12-10 09:23:05 (50.5 minutes) and wrote 0 records for ZT-201903-ECBOT | 2018-12-10 09:33:07 HD Request # 69 | Completion time: 1s | 2018-12-10 09:33:07 HD Request # 69 | Intraday data download complete for ZT-201903-ECBOT. Unique request ID: 68 | 2018-12-10 09:33:07 Removed historical data download ID 68 | 2018-12-10 09:33:07 Real-time Intraday chart data file updates started for ZT-201903-ECBOT | 2018-12-10 09:33:07 Intraday chart data file opened for ZT-201903-ECBOT | 2018-12-10 09:33:07 Interactive Brokers | Using primary service for historical data for ZT-201903-ECBOT | 2018-12-10 09:33:07 Intraday data recording state for symbol ZT-201903-ECBOT is set to download 'Pending'. | 2018-12-10 09:33:07 HD Request # 70 | Downloading Intraday chart data for ZT-201903-ECBOT to the file ZT-201903-ECBOT.scid. Service: interactive_brokers.trading | 2018-12-10 09:33:07 HD Request # 70 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:07 HD Request # 70 | Requesting a total of 0 days and 4826 seconds. | 2018-12-10 09:33:07 HD Request # 70 | IB Backfill - Seconds requested: 4826. Seconds Remaining: 0. | 2018-12-10 09:33:07 HD Request # 70 | Requesting 4826 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:06 for ZT-201903-ECBOT. PriceType: TRADES | 2018-12-10 09:33:07 HD Request # 71 | Downloading Intraday chart data for ZN-201903-ECBOT to the file ZN-201903-ECBOT.scid. Service: cbot | 2018-12-10 09:33:07 HD Request # 71 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:07 HD Request # 71 | Using server: ds7.sierracharts.com port 10149 | 2018-12-10 09:33:07 Socket (5) | Creating socket. | 2018-12-10 09:33:07 Socket (5) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:07 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:07 Socket (4) | Closed. | 2018-12-10 09:33:07 HD Request # 70 | Processing historical data message from TWS | 2018-12-10 09:33:07 HD Request # 70 | Receiving Intraday data for ZT-201903-ECBOT starting at 2018-12-10 09:23:00 | 2018-12-10 09:33:07 HD Request # 70 | Timestamp of first Intraday data file record written: 2018-12-10 09:33:00 | 2018-12-10 09:33:07 HD Request # 70 | Received 22 records and wrote 1 records from 2018-12-10 09:22:30 to 2018-12-10 09:33:00. | 2018-12-10 09:33:07 HD Request # 70 | Received 22 records from 2018-12-10 09:23:00 to 2018-12-10 09:33:00 (10.0 minutes) and wrote 1 record for ZT-201903-ECBOT | 2018-12-10 09:33:07 HD Request # 70 | Completion time: 1s | 2018-12-10 09:33:07 HD Request # 70 | Intraday data download complete for ZT-201903-ECBOT. Unique request ID: 85 | 2018-12-10 09:33:07 Removed historical data download ID 85 | 2018-12-10 09:33:07 Real-time Intraday chart data file updates started for ZT-201903-ECBOT | 2018-12-10 09:33:07 Intraday chart data file opened for ZT-201903-ECBOT | 2018-12-10 09:33:07 HD Request # 71 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:07 HD Request # 71 | Sending historical data logon request message. | 2018-12-10 09:33:07 HD Request # 71 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:40. Record interval: 0. Symbol: ZNH19 | 2018-12-10 09:33:07 HD Request # 71 | Decompressing data. | 2018-12-10 09:33:08 Socket (5) | Signaling to core to close socket | 2018-12-10 09:33:08 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:08 Historical data download thread signaled to stop. | 2018-12-10 09:33:08 HD Request # 71 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZN-201903-ECBOT | 2018-12-10 09:33:08 HD Request # 71 | Completion time: 0s | 2018-12-10 09:33:08 HD Request # 71 | Intraday data download complete for ZN-201903-ECBOT. Unique request ID: 69 | 2018-12-10 09:33:08 Removed historical data download ID 69 | 2018-12-10 09:33:08 Real-time Intraday chart data file updates started for ZN-201903-ECBOT | 2018-12-10 09:33:08 Intraday chart data file opened for ZN-201903-ECBOT | 2018-12-10 09:33:08 Interactive Brokers | Using primary service for historical data for ZN-201903-ECBOT | 2018-12-10 09:33:08 Intraday data recording state for symbol ZN-201903-ECBOT is set to download 'Pending'. | 2018-12-10 09:33:08 HD Request # 72 | Downloading Intraday chart data for ZN-201903-ECBOT to the file ZN-201903-ECBOT.scid. Service: interactive_brokers.trading | 2018-12-10 09:33:08 HD Request # 72 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:08 HD Request # 72 | Requesting a total of 0 days and 4827 seconds. | 2018-12-10 09:33:08 HD Request # 72 | IB Backfill - Seconds requested: 4827. Seconds Remaining: 0. | 2018-12-10 09:33:08 HD Request # 72 | Requesting 4827 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:07 for ZN-201903-ECBOT. PriceType: TRADES | 2018-12-10 09:33:08 HD Request # 73 | Downloading Intraday chart data for $TYX to the file $TYX.scid. Service: cboe.index | 2018-12-10 09:33:08 HD Request # 73 | Download start date-time: 2018-12-10 08:34:06.000 | 2018-12-10 09:33:08 HD Request # 73 | Using server: ds1.sierracharts.com port 10150 | 2018-12-10 09:33:08 Socket (4) | Creating socket. | 2018-12-10 09:33:08 Socket (4) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:33:08 Chart #3 has tagged chart #13 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:08 Chart #3 has tagged chart #14 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:08 Socket (5) | Socket gracefully closed by remote side. | 2018-12-10 09:33:08 Socket (5) | Closed. | 2018-12-10 09:33:08 HD Request # 72 | Processing historical data message from TWS | 2018-12-10 09:33:08 HD Request # 72 | Receiving Intraday data for ZN-201903-ECBOT starting at 2018-12-10 09:23:00 | 2018-12-10 09:33:08 HD Request # 72 | Timestamp of first Intraday data file record written: 2018-12-10 09:33:00 | 2018-12-10 09:33:08 HD Request # 72 | Received 22 records and wrote 1 records from 2018-12-10 09:22:30 to 2018-12-10 09:33:00. | 2018-12-10 09:33:08 HD Request # 72 | Received 22 records from 2018-12-10 09:23:00 to 2018-12-10 09:33:00 (10.0 minutes) and wrote 1 record for ZN-201903-ECBOT | 2018-12-10 09:33:08 HD Request # 72 | Completion time: 0s | 2018-12-10 09:33:08 HD Request # 72 | Intraday data download complete for ZN-201903-ECBOT. Unique request ID: 86 | 2018-12-10 09:33:08 Removed historical data download ID 86 | 2018-12-10 09:33:08 Real-time Intraday chart data file updates started for ZN-201903-ECBOT | 2018-12-10 09:33:08 Intraday chart data file opened for ZN-201903-ECBOT | 2018-12-10 09:33:08 ZF-201903-ECBOT 60 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:08 ZT-201903-ECBOT 60 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:08 Chart #3 has tagged chart #13 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:08 Chart #3 has tagged chart #14 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:08 HD Request # 73 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:08 HD Request # 73 | Sending historical data logon request message. | 2018-12-10 09:33:08 ZF-201903-ECBOT 60 Min #14 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:08 ZT-201903-ECBOT 60 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:08 HD Request # 73 | Requesting Intraday data. Start date-time: 2018-12-10 08:34:06. Record interval: 0. Symbol: $TYX | 2018-12-10 09:33:08 HD Request # 73 | Decompressing data. | 2018-12-10 09:33:09 HD Request # 73 | Receiving Intraday data for $TYX starting at 2018-12-10 08:34:06 | 2018-12-10 09:33:09 HD Request # 73 | Timestamp of first Intraday data file record written: 2018-12-10 08:34:16 | 2018-12-10 09:33:09 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:09 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:09 Historical data download thread signaled to stop. | 2018-12-10 09:33:09 HD Request # 73 | Received 265 records from 2018-12-10 08:34:06 to 2018-12-10 09:18:06 (44.0 minutes) and wrote 264 records for $TYX | 2018-12-10 09:33:09 HD Request # 73 | Completion time: 1s | 2018-12-10 09:33:09 HD Request # 73 | Intraday data download complete for $TYX. Unique request ID: 70 | 2018-12-10 09:33:09 Removed historical data download ID 70 | 2018-12-10 09:33:09 Real-time Intraday chart data file updates started for $TYX | 2018-12-10 09:33:09 Intraday chart data file opened for $TYX | 2018-12-10 09:33:09 Interactive Brokers | Using primary service for historical data for $TYX | 2018-12-10 09:33:09 Intraday data recording state for symbol $TYX is set to download 'Pending'. | 2018-12-10 09:33:09 HD Request # 74 | Downloading Intraday chart data for $TYX to the file $TYX.scid. Service: cboe.index | 2018-12-10 09:33:09 HD Request # 74 | Download start date-time: 2018-12-10 09:18:06.000 | 2018-12-10 09:33:09 HD Request # 74 | Requesting a total of 0 days and 5702 seconds. | 2018-12-10 09:33:09 HD Request # 74 | IB Backfill - Seconds requested: 5702. Seconds Remaining: 0. | 2018-12-10 09:33:09 HD Request # 74 | Requesting 5702 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:08 for $TYX. PriceType: TRADES | 2018-12-10 09:33:09 HD Request # 75 | Downloading Intraday chart data for ZB-201903-ECBOT to the file ZB-201903-ECBOT.scid. Service: cbot | 2018-12-10 09:33:09 HD Request # 75 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:09 HD Request # 75 | Using server: ds7.sierracharts.com port 10149 | 2018-12-10 09:33:09 Socket (5) | Creating socket. | 2018-12-10 09:33:09 Socket (5) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:09 Opened cached Intraday file: C:\SierraChart\Data\ZB-201812-ECBOT.scid | 2018-12-10 09:33:09 HD Request # 74 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200009. | 2018-12-10 09:33:09 HD Request # 74 | Error downloading historical Intraday data for $TYX. The symbol is unknown to the server. | 2018-12-10 09:33:09 HD Request # 74 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TYX | 2018-12-10 09:33:09 HD Request # 74 | Completion time: 0s | 2018-12-10 09:33:09 HD Request # 74 | Intraday data download complete for $TYX. Unique request ID: 87 | 2018-12-10 09:33:09 Removed historical data download ID 87 | 2018-12-10 09:33:09 Real-time Intraday chart data file updates started for $TYX | 2018-12-10 09:33:09 Intraday chart data file opened for $TYX | 2018-12-10 09:33:09 Message from IB: No historical data query found for ticker id:200009. IB Error Code: 366. Request ID: 200009. | 2018-12-10 09:33:09 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:09 Socket (4) | Closed. | 2018-12-10 09:33:09 HD Request # 75 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:09 HD Request # 75 | Sending historical data logon request message. | 2018-12-10 09:33:09 HD Request # 75 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:40. Record interval: 0. Symbol: ZBH19 | 2018-12-10 09:33:09 HD Request # 75 | Decompressing data. | 2018-12-10 09:33:10 Socket (5) | Signaling to core to close socket | 2018-12-10 09:33:10 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:10 Historical data download thread signaled to stop. | 2018-12-10 09:33:10 HD Request # 75 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZB-201903-ECBOT | 2018-12-10 09:33:10 HD Request # 75 | Completion time: 1s | 2018-12-10 09:33:10 HD Request # 75 | Intraday data download complete for ZB-201903-ECBOT. Unique request ID: 71 | 2018-12-10 09:33:10 Removed historical data download ID 71 | 2018-12-10 09:33:10 Real-time Intraday chart data file updates started for ZB-201903-ECBOT | 2018-12-10 09:33:10 Intraday chart data file opened for ZB-201903-ECBOT | 2018-12-10 09:33:10 Interactive Brokers | Using primary service for historical data for ZB-201903-ECBOT | 2018-12-10 09:33:10 Intraday data recording state for symbol ZB-201903-ECBOT is set to download 'Pending'. | 2018-12-10 09:33:10 HD Request # 76 | Downloading Intraday chart data for ZB-201903-ECBOT to the file ZB-201903-ECBOT.scid. Service: interactive_brokers.trading | 2018-12-10 09:33:10 HD Request # 76 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:10 HD Request # 76 | Requesting a total of 0 days and 4829 seconds. | 2018-12-10 09:33:10 HD Request # 76 | IB Backfill - Seconds requested: 4829. Seconds Remaining: 0. | 2018-12-10 09:33:10 HD Request # 76 | Requesting 4829 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:09 for ZB-201903-ECBOT. PriceType: TRADES | 2018-12-10 09:33:10 HD Request # 77 | Downloading Intraday chart data for nisS-NYSE to the file nisS-NYSE.scid. Service: statscalc | 2018-12-10 09:33:10 HD Request # 77 | Download start date-time: 2018-12-10 09:32:46.000 | 2018-12-10 09:33:10 HD Request # 77 | Using server: ds4.sierracharts.com port 10150 | 2018-12-10 09:33:10 Socket (4) | Creating socket. | 2018-12-10 09:33:10 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-12-10 09:33:10 Socket (5) | Socket gracefully closed by remote side. | 2018-12-10 09:33:10 Socket (5) | Closed. | 2018-12-10 09:33:10 HD Request # 76 | Processing historical data message from TWS | 2018-12-10 09:33:10 HD Request # 76 | Receiving Intraday data for ZB-201903-ECBOT starting at 2018-12-10 09:23:00 | 2018-12-10 09:33:10 HD Request # 76 | Timestamp of first Intraday data file record written: 2018-12-10 09:33:00 | 2018-12-10 09:33:10 HD Request # 76 | Received 22 records and wrote 1 records from 2018-12-10 09:22:30 to 2018-12-10 09:33:00. | 2018-12-10 09:33:10 HD Request # 76 | Received 22 records from 2018-12-10 09:23:00 to 2018-12-10 09:33:00 (10.0 minutes) and wrote 1 record for ZB-201903-ECBOT | 2018-12-10 09:33:10 HD Request # 76 | Completion time: 0s | 2018-12-10 09:33:10 HD Request # 76 | Intraday data download complete for ZB-201903-ECBOT. Unique request ID: 88 | 2018-12-10 09:33:10 Removed historical data download ID 88 | 2018-12-10 09:33:10 Real-time Intraday chart data file updates started for ZB-201903-ECBOT | 2018-12-10 09:33:10 Intraday chart data file opened for ZB-201903-ECBOT | 2018-12-10 09:33:10 HD Request # 77 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:10 HD Request # 77 | Sending historical data logon request message. | 2018-12-10 09:33:10 HD Request # 77 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:46. Record interval: 0. Symbol: nisS-NYSE | 2018-12-10 09:33:10 HD Request # 77 | Decompressing data. | 2018-12-10 09:33:11 HD Request # 77 | Receiving Intraday data for nisS-NYSE starting at 2018-12-10 09:32:46 | 2018-12-10 09:33:11 HD Request # 77 | Timestamp of first Intraday data file record written: 2018-12-10 09:32:47 | 2018-12-10 09:33:11 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:11 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:11 Historical data download thread signaled to stop. | 2018-12-10 09:33:11 HD Request # 77 | Received 22 records from 2018-12-10 09:32:46 to 2018-12-10 09:33:08 (22.0 seconds) and wrote 21 records for nisS-NYSE | 2018-12-10 09:33:11 HD Request # 77 | Completion time: 0s | 2018-12-10 09:33:11 HD Request # 77 | Intraday data download complete for nisS-NYSE. Unique request ID: 73 | 2018-12-10 09:33:11 Removed historical data download ID 73 | 2018-12-10 09:33:11 Real-time Intraday chart data file updates started for nisS-NYSE | 2018-12-10 09:33:11 Intraday chart data file opened for nisS-NYSE | 2018-12-10 09:33:11 HD Request # 78 | Downloading Intraday chart data for ASHR-STK-SMART to the file ASHR-STK-SMART.scid. Service: equities.us | 2018-12-10 09:33:11 HD Request # 78 | Download start date-time: 2018-12-10 08:00:05.000 | 2018-12-10 09:33:11 HD Request # 78 | Using server: ds1.sierracharts.com port 10149 | 2018-12-10 09:33:11 Socket (5) | Creating socket. | 2018-12-10 09:33:11 Socket (5) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:33:11 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:11 Socket (4) | Closed. | 2018-12-10 09:33:11 HD Request # 78 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:11 HD Request # 78 | Sending historical data logon request message. | 2018-12-10 09:33:11 HD Request # 78 | Requesting Intraday data. Start date-time: 2018-12-10 08:00:05. Record interval: 0. Symbol: ASHR | 2018-12-10 09:33:11 Opened cached Intraday file: C:\SierraChart\Data\ZT-201903-ECBOT.scid | 2018-12-10 09:33:12 Opened cached Intraday file: C:\SierraChart\Data\ZN-201903-ECBOT.scid | 2018-12-10 09:33:12 Opened cached Intraday file: C:\SierraChart\Data\ZB-201903-ECBOT.scid | 2018-12-10 09:33:12 Opened cached Intraday file: C:\SierraChart\Data\nisS-NYSE.scid | 2018-12-10 09:33:12 HD Request # 78 | Decompressing data. | 2018-12-10 09:33:12 HD Request # 78 | Receiving Intraday data for ASHR-STK-SMART starting at 2018-12-10 08:00:05 | 2018-12-10 09:33:12 Socket (5) | Signaling to core to close socket | 2018-12-10 09:33:12 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:12 Historical data download thread signaled to stop. | 2018-12-10 09:33:12 HD Request # 78 | Received 1 record from 2018-12-10 08:00:05 to 2018-12-10 08:00:05 (0.0 seconds) and wrote 0 records for ASHR-STK-SMART | 2018-12-10 09:33:12 HD Request # 78 | Completion time: 0s | 2018-12-10 09:33:12 HD Request # 78 | Intraday data download complete for ASHR-STK-SMART. Unique request ID: 74 | 2018-12-10 09:33:12 Removed historical data download ID 74 | 2018-12-10 09:33:12 Real-time Intraday chart data file updates started for ASHR-STK-SMART | 2018-12-10 09:33:12 Intraday chart data file opened for ASHR-STK-SMART | 2018-12-10 09:33:12 Interactive Brokers | Using primary service for historical data for ASHR-STK-SMART | 2018-12-10 09:33:12 Intraday data recording state for symbol ASHR-STK-SMART is set to download 'Pending'. | 2018-12-10 09:33:12 HD Request # 79 | Downloading Intraday chart data for ASHR-STK-SMART to the file ASHR-STK-SMART.scid. Service: interactive_brokers.trading | 2018-12-10 09:33:12 HD Request # 79 | Download start date-time: 2018-12-10 08:00:05.000 | 2018-12-10 09:33:12 HD Request # 79 | Requesting a total of 0 days and 10386 seconds. | 2018-12-10 09:33:12 HD Request # 79 | IB Backfill - Seconds requested: 10386. Seconds Remaining: 0. | 2018-12-10 09:33:12 HD Request # 79 | Requesting 10386 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:11 for ASHR-STK-SMART. PriceType: TRADES | 2018-12-10 09:33:12 HD Request # 80 | Downloading Intraday chart data for HG-201807-NYMEX to the file HG-201807-NYMEX.scid. Service: comex | 2018-12-10 09:33:12 HD Request # 80 | Download start date-time: 2018-07-27 12:51:45.000 | 2018-12-10 09:33:12 HD Request # 80 | Using server: ds7.sierracharts.com port 10150 | 2018-12-10 09:33:12 Socket (4) | Creating socket. | 2018-12-10 09:33:12 Socket (4) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:12 HD Request # 79 | Message from IB: The contract description specified for ASHR is ambiguous. IB Error Code: 200. Request ID: 200011. | 2018-12-10 09:33:12 HD Request # 79 | Error downloading historical Intraday data for ASHR-STK-SMART. The symbol is unknown to the server. | 2018-12-10 09:33:12 HD Request # 79 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ASHR-STK-SMART | 2018-12-10 09:33:12 HD Request # 79 | Completion time: 0s | 2018-12-10 09:33:12 HD Request # 79 | Intraday data download complete for ASHR-STK-SMART. Unique request ID: 89 | 2018-12-10 09:33:12 Removed historical data download ID 89 | 2018-12-10 09:33:12 Real-time Intraday chart data file updates started for ASHR-STK-SMART | 2018-12-10 09:33:12 Intraday chart data file opened for ASHR-STK-SMART | 2018-12-10 09:33:12 Message from IB: No historical data query found for ticker id:200011. IB Error Code: 366. Request ID: 200011. | 2018-12-10 09:33:12 Socket (5) | Socket gracefully closed by remote side. | 2018-12-10 09:33:12 Socket (5) | Closed. | 2018-12-10 09:33:12 HD Request # 80 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:12 HD Request # 80 | Sending historical data logon request message. | 2018-12-10 09:33:12 HD Request # 80 | Requesting Intraday data. Start date-time: 2018-07-27 12:51:45. Record interval: 0. Symbol: HGN18 | 2018-12-10 09:33:13 HD Request # 80 | Decompressing data. | 2018-12-10 09:33:13 HD Request # 80 | Receiving Intraday data for HG-201807-NYMEX starting at 2018-07-26 14:38:14 | 2018-12-10 09:33:13 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:13 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:13 Historical data download thread signaled to stop. | 2018-12-10 09:33:13 HD Request # 80 | Received 2 records from 2018-07-26 14:38:14 to 2018-07-26 15:36:22 (58.1 minutes) and wrote 0 records for HG-201807-NYMEX | 2018-12-10 09:33:13 HD Request # 80 | Completion time: 2s | 2018-12-10 09:33:13 HD Request # 80 | Intraday data download complete for HG-201807-NYMEX. Unique request ID: 75 | 2018-12-10 09:33:13 Removed historical data download ID 75 | 2018-12-10 09:33:13 Real-time Intraday chart data file updates started for HG-201807-NYMEX | 2018-12-10 09:33:13 Intraday chart data file opened for HG-201807-NYMEX | 2018-12-10 09:33:13 HD Request # 81 | Downloading Intraday chart data for $FVX to the file $FVX.scid. Service: cboe.index | 2018-12-10 09:33:13 HD Request # 81 | Download start date-time: 2018-12-10 08:38:56.000 | 2018-12-10 09:33:13 HD Request # 81 | Using server: ds1.sierracharts.com port 10149 | 2018-12-10 09:33:13 Socket (3) | Creating socket. | 2018-12-10 09:33:13 Socket (3) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:33:13 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:13 Socket (4) | Closed. | 2018-12-10 09:33:13 HD Request # 81 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:14 HD Request # 81 | Sending historical data logon request message. | 2018-12-10 09:33:14 HD Request # 81 | Requesting Intraday data. Start date-time: 2018-12-10 08:38:56. Record interval: 0. Symbol: $FVX | 2018-12-10 09:33:14 HD Request # 81 | Decompressing data. | 2018-12-10 09:33:15 HD Request # 81 | Receiving Intraday data for $FVX starting at 2018-12-10 08:38:56 | 2018-12-10 09:33:15 HD Request # 81 | Timestamp of first Intraday data file record written: 2018-12-10 08:39:06 | 2018-12-10 09:33:15 Socket (3) | Signaling to core to close socket | 2018-12-10 09:33:15 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:15 Historical data download thread signaled to stop. | 2018-12-10 09:33:15 HD Request # 81 | Received 237 records from 2018-12-10 08:38:56 to 2018-12-10 09:18:16 (39.3 minutes) and wrote 236 records for $FVX | 2018-12-10 09:33:15 HD Request # 81 | Completion time: 1s | 2018-12-10 09:33:15 HD Request # 81 | Intraday data download complete for $FVX. Unique request ID: 76 | 2018-12-10 09:33:15 Removed historical data download ID 76 | 2018-12-10 09:33:15 Real-time Intraday chart data file updates started for $FVX | 2018-12-10 09:33:15 Intraday chart data file opened for $FVX | 2018-12-10 09:33:15 Interactive Brokers | Using primary service for historical data for $FVX | 2018-12-10 09:33:15 Intraday data recording state for symbol $FVX is set to download 'Pending'. | 2018-12-10 09:33:15 HD Request # 82 | Downloading Intraday chart data for $FVX to the file $FVX.scid. Service: cboe.index | 2018-12-10 09:33:15 HD Request # 82 | Download start date-time: 2018-12-10 09:18:16.000 | 2018-12-10 09:33:15 HD Request # 82 | Requesting a total of 0 days and 5698 seconds. | 2018-12-10 09:33:15 HD Request # 82 | IB Backfill - Seconds requested: 5698. Seconds Remaining: 0. | 2018-12-10 09:33:15 HD Request # 82 | Requesting 5698 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:14 for $FVX. PriceType: TRADES | 2018-12-10 09:33:15 HD Request # 83 | Downloading Intraday chart data for ZF-201903-ECBOT to the file ZF-201903-ECBOT.scid. Service: cbot | 2018-12-10 09:33:15 HD Request # 83 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:15 HD Request # 83 | Using server: ds7.sierracharts.com port 10150 | 2018-12-10 09:33:15 Socket (4) | Creating socket. | 2018-12-10 09:33:15 Socket (4) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:15 HD Request # 82 | Message from IB: No security definition has been found for the request. IB Error Code: 200. Request ID: 200012. | 2018-12-10 09:33:15 HD Request # 82 | Error downloading historical Intraday data for $FVX. The symbol is unknown to the server. | 2018-12-10 09:33:15 HD Request # 82 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $FVX | 2018-12-10 09:33:15 HD Request # 82 | Completion time: 0s | 2018-12-10 09:33:15 HD Request # 82 | Intraday data download complete for $FVX. Unique request ID: 90 | 2018-12-10 09:33:15 Removed historical data download ID 90 | 2018-12-10 09:33:15 Real-time Intraday chart data file updates started for $FVX | 2018-12-10 09:33:15 Intraday chart data file opened for $FVX | 2018-12-10 09:33:15 Message from IB: No historical data query found for ticker id:200012. IB Error Code: 366. Request ID: 200012. | 2018-12-10 09:33:15 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:33:15 Socket (3) | Closed. | 2018-12-10 09:33:15 HD Request # 83 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:15 HD Request # 83 | Sending historical data logon request message. | 2018-12-10 09:33:15 HD Request # 83 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:40. Record interval: 0. Symbol: ZFH19 | 2018-12-10 09:33:16 HD Request # 83 | Decompressing data. | 2018-12-10 09:33:16 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:16 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:16 Historical data download thread signaled to stop. | 2018-12-10 09:33:16 HD Request # 83 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for ZF-201903-ECBOT | 2018-12-10 09:33:16 HD Request # 83 | Completion time: 1s | 2018-12-10 09:33:16 HD Request # 83 | Intraday data download complete for ZF-201903-ECBOT. Unique request ID: 77 | 2018-12-10 09:33:16 Removed historical data download ID 77 | 2018-12-10 09:33:16 Real-time Intraday chart data file updates started for ZF-201903-ECBOT | 2018-12-10 09:33:16 Intraday chart data file opened for ZF-201903-ECBOT | 2018-12-10 09:33:16 Interactive Brokers | Using primary service for historical data for ZF-201903-ECBOT | 2018-12-10 09:33:16 Intraday data recording state for symbol ZF-201903-ECBOT is set to download 'Pending'. | 2018-12-10 09:33:16 HD Request # 84 | Downloading Intraday chart data for ZF-201903-ECBOT to the file ZF-201903-ECBOT.scid. Service: interactive_brokers.trading | 2018-12-10 09:33:16 HD Request # 84 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:16 HD Request # 84 | Requesting a total of 0 days and 4835 seconds. | 2018-12-10 09:33:16 HD Request # 84 | IB Backfill - Seconds requested: 4835. Seconds Remaining: 0. | 2018-12-10 09:33:16 HD Request # 84 | Requesting 4835 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:15 for ZF-201903-ECBOT. PriceType: TRADES | 2018-12-10 09:33:16 HD Request # 85 | Downloading Intraday chart data for UB-201903-ECBOT-USD to the file UB-201903-ECBOT-USD.scid. Service: cbot | 2018-12-10 09:33:16 HD Request # 85 | Download start date-time: 2018-12-10 09:32:46.000 | 2018-12-10 09:33:16 HD Request # 85 | Using server: ds1.sierracharts.com port 10149 | 2018-12-10 09:33:16 Socket (3) | Creating socket. | 2018-12-10 09:33:16 Socket (3) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:33:16 Chart #2 has tagged chart #13 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:16 Chart #2 has tagged chart #9 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:16 ZT-201903-ECBOT 60 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:16 ZT-201903-ECBOT 60 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:16 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:16 Socket (4) | Closed. | 2018-12-10 09:33:16 HD Request # 85 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:16 HD Request # 85 | Sending historical data logon request message. | 2018-12-10 09:33:16 HD Request # 84 | Processing historical data message from TWS | 2018-12-10 09:33:16 HD Request # 84 | Receiving Intraday data for ZF-201903-ECBOT starting at 2018-12-10 09:23:00 | 2018-12-10 09:33:16 HD Request # 84 | Timestamp of first Intraday data file record written: 2018-12-10 09:33:00 | 2018-12-10 09:33:16 HD Request # 84 | Received 22 records and wrote 1 records from 2018-12-10 09:22:30 to 2018-12-10 09:33:00. | 2018-12-10 09:33:16 HD Request # 84 | Received 22 records from 2018-12-10 09:23:00 to 2018-12-10 09:33:00 (10.0 minutes) and wrote 1 record for ZF-201903-ECBOT | 2018-12-10 09:33:16 HD Request # 84 | Completion time: 0s | 2018-12-10 09:33:16 HD Request # 84 | Intraday data download complete for ZF-201903-ECBOT. Unique request ID: 91 | 2018-12-10 09:33:16 Removed historical data download ID 91 | 2018-12-10 09:33:16 Real-time Intraday chart data file updates started for ZF-201903-ECBOT | 2018-12-10 09:33:16 Intraday chart data file opened for ZF-201903-ECBOT | 2018-12-10 09:33:16 Chart #2 has tagged chart #13 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:16 Chart #2 has tagged chart #9 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:16 ZT-201903-ECBOT 60 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:16 ZT-201903-ECBOT 60 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 HD Request # 85 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:46. Record interval: 0. Symbol: UBH19 | 2018-12-10 09:33:17 HD Request # 85 | Decompressing data. | 2018-12-10 09:33:17 Socket (3) | Signaling to core to close socket | 2018-12-10 09:33:17 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:17 Historical data download thread signaled to stop. | 2018-12-10 09:33:17 HD Request # 85 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for UB-201903-ECBOT-USD | 2018-12-10 09:33:17 HD Request # 85 | Completion time: 1s | 2018-12-10 09:33:17 HD Request # 85 | Intraday data download complete for UB-201903-ECBOT-USD. Unique request ID: 78 | 2018-12-10 09:33:17 Removed historical data download ID 78 | 2018-12-10 09:33:17 Real-time Intraday chart data file updates started for UB-201903-ECBOT-USD | 2018-12-10 09:33:17 Intraday chart data file opened for UB-201903-ECBOT-USD | 2018-12-10 09:33:17 Interactive Brokers | Using primary service for historical data for UB-201903-ECBOT-USD | 2018-12-10 09:33:17 Intraday data recording state for symbol UB-201903-ECBOT-USD is set to download 'Pending'. | 2018-12-10 09:33:17 HD Request # 86 | Downloading Intraday chart data for UB-201903-ECBOT-USD to the file UB-201903-ECBOT-USD.scid. Service: interactive_brokers.trading | 2018-12-10 09:33:17 HD Request # 86 | Download start date-time: 2018-12-10 09:32:46.000 | 2018-12-10 09:33:17 HD Request # 86 | Requesting a total of 0 days and 4830 seconds. | 2018-12-10 09:33:17 HD Request # 86 | IB Backfill - Seconds requested: 4830. Seconds Remaining: 0. | 2018-12-10 09:33:17 HD Request # 86 | Requesting 4830 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:16 for UB-201903-ECBOT-USD. PriceType: TRADES | 2018-12-10 09:33:17 HD Request # 87 | Downloading Intraday chart data for NQ-201812-GLOBEX to the file NQ-201812-GLOBEX.scid. Service: cme | 2018-12-10 09:33:17 HD Request # 87 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:17 HD Request # 87 | Using server: ds7.sierracharts.com port 10150 | 2018-12-10 09:33:17 Socket (4) | Creating socket. | 2018-12-10 09:33:17 Socket (4) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:17 Chart #5 has tagged chart #12 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 Chart #5 has tagged chart #15 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 ZN-201903-ECBOT 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:33:17 ZB-201903-ECBOT [C] 60 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 Socket (3) | Closed. | 2018-12-10 09:33:17 HD Request # 86 | Processing historical data message from TWS | 2018-12-10 09:33:17 HD Request # 86 | Receiving Intraday data for UB-201903-ECBOT-USD starting at 2018-12-10 09:23:00 | 2018-12-10 09:33:17 HD Request # 86 | Timestamp of first Intraday data file record written: 2018-12-10 09:33:00 | 2018-12-10 09:33:17 HD Request # 86 | Received 22 records and wrote 1 records from 2018-12-10 09:22:30 to 2018-12-10 09:33:00. | 2018-12-10 09:33:17 HD Request # 86 | Received 22 records from 2018-12-10 09:23:00 to 2018-12-10 09:33:00 (10.0 minutes) and wrote 1 record for UB-201903-ECBOT-USD | 2018-12-10 09:33:17 HD Request # 86 | Completion time: 1s | 2018-12-10 09:33:17 HD Request # 86 | Intraday data download complete for UB-201903-ECBOT-USD. Unique request ID: 92 | 2018-12-10 09:33:17 Removed historical data download ID 92 | 2018-12-10 09:33:17 Real-time Intraday chart data file updates started for UB-201903-ECBOT-USD | 2018-12-10 09:33:17 Intraday chart data file opened for UB-201903-ECBOT-USD | 2018-12-10 09:33:17 Chart #5 has tagged chart #12 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 Chart #5 has tagged chart #15 for full recalculation. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 ZN-201903-ECBOT 60 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 ZB-201903-ECBOT [C] 60 Min #12 | Performing a full recalculation because it has been tagged. Chartbook: Treasury Spreads.cht | 2018-12-10 09:33:17 HD Request # 87 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:17 HD Request # 87 | Sending historical data logon request message. | 2018-12-10 09:33:17 HD Request # 87 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:40. Record interval: 0. Symbol: NQZ18 | 2018-12-10 09:33:18 HD Request # 87 | Decompressing data. | 2018-12-10 09:33:18 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:18 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:18 Historical data download thread signaled to stop. | 2018-12-10 09:33:18 HD Request # 87 | Received 1 record from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for NQ-201812-GLOBEX | 2018-12-10 09:33:18 HD Request # 87 | Completion time: 1s | 2018-12-10 09:33:18 HD Request # 87 | Intraday data download complete for NQ-201812-GLOBEX. Unique request ID: 79 | 2018-12-10 09:33:18 Removed historical data download ID 79 | 2018-12-10 09:33:18 Real-time Intraday chart data file updates started for NQ-201812-GLOBEX | 2018-12-10 09:33:18 Intraday chart data file opened for NQ-201812-GLOBEX | 2018-12-10 09:33:18 Interactive Brokers | Using primary service for historical data for NQ-201812-GLOBEX | 2018-12-10 09:33:18 Intraday data recording state for symbol NQ-201812-GLOBEX is set to download 'Pending'. | 2018-12-10 09:33:18 HD Request # 88 | Downloading Intraday chart data for NQ-201812-GLOBEX to the file NQ-201812-GLOBEX.scid. Service: interactive_brokers.trading | 2018-12-10 09:33:18 HD Request # 88 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:18 HD Request # 88 | Requesting a total of 0 days and 4837 seconds. | 2018-12-10 09:33:18 HD Request # 88 | IB Backfill - Seconds requested: 4837. Seconds Remaining: 0. | 2018-12-10 09:33:18 HD Request # 88 | Requesting 4837 Seconds of data at 30 secs with ending date-time at 2018-12-10 10:43:17 for NQ-201812-GLOBEX. PriceType: TRADES | 2018-12-10 09:33:18 HD Request # 89 | Downloading Intraday chart data for GC-201812-NYMEX to the file GC-201812-NYMEX.scid. Service: comex | 2018-12-10 09:33:18 HD Request # 89 | Download start date-time: 2018-12-10 09:32:40.000 | 2018-12-10 09:33:18 HD Request # 89 | Using server: ds1.sierracharts.com port 10149 | 2018-12-10 09:33:18 Socket (3) | Creating socket. | 2018-12-10 09:33:18 Socket (3) | Connecting to IP: 8.18.161.135. | 2018-12-10 09:33:18 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:18 Socket (4) | Closed. | 2018-12-10 09:33:18 HD Request # 88 | Processing historical data message from TWS | 2018-12-10 09:33:18 HD Request # 88 | Receiving Intraday data for NQ-201812-GLOBEX starting at 2018-12-10 09:23:00 | 2018-12-10 09:33:18 HD Request # 88 | Timestamp of first Intraday data file record written: 2018-12-10 09:33:00 | 2018-12-10 09:33:18 HD Request # 88 | Received 22 records and wrote 1 records from 2018-12-10 09:22:30 to 2018-12-10 09:33:00. | 2018-12-10 09:33:18 HD Request # 88 | Received 22 records from 2018-12-10 09:23:00 to 2018-12-10 09:33:00 (10.0 minutes) and wrote 1 record for NQ-201812-GLOBEX | 2018-12-10 09:33:18 HD Request # 88 | Completion time: 1s | 2018-12-10 09:33:18 HD Request # 88 | Intraday data download complete for NQ-201812-GLOBEX. Unique request ID: 93 | 2018-12-10 09:33:18 Removed historical data download ID 93 | 2018-12-10 09:33:18 Real-time Intraday chart data file updates started for NQ-201812-GLOBEX | 2018-12-10 09:33:18 Intraday chart data file opened for NQ-201812-GLOBEX | 2018-12-10 09:33:18 HD Request # 89 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:18 HD Request # 89 | Sending historical data logon request message. | 2018-12-10 09:33:18 HD Request # 89 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:40. Record interval: 0. Symbol: GCZ18 | 2018-12-10 09:33:19 HD Request # 89 | Decompressing data. | 2018-12-10 09:33:19 HD Request # 89 | Receiving Intraday data for GC-201812-NYMEX starting at 2018-12-10 07:18:59 | 2018-12-10 09:33:19 Socket (3) | Signaling to core to close socket | 2018-12-10 09:33:19 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:19 Historical data download thread signaled to stop. | 2018-12-10 09:33:19 HD Request # 89 | Received 6 records from 2018-12-10 07:18:59 to 2018-12-10 08:06:01 (47.0 minutes) and wrote 0 records for GC-201812-NYMEX | 2018-12-10 09:33:19 HD Request # 89 | Completion time: 1s | 2018-12-10 09:33:19 HD Request # 89 | Intraday data download complete for GC-201812-NYMEX. Unique request ID: 80 | 2018-12-10 09:33:19 Removed historical data download ID 80 | 2018-12-10 09:33:19 Real-time Intraday chart data file updates started for GC-201812-NYMEX | 2018-12-10 09:33:19 Intraday chart data file opened for GC-201812-NYMEX | 2018-12-10 09:33:19 HD Request # 90 | Downloading Intraday chart data for NG-201812-NYMEX to the file NG-201812-NYMEX.scid. Service: nymex | 2018-12-10 09:33:19 HD Request # 90 | Download start date-time: 2018-11-28 14:29:52.000 | 2018-12-10 09:33:19 HD Request # 90 | Using server: ds7.sierracharts.com port 10150 | 2018-12-10 09:33:19 Socket (4) | Creating socket. | 2018-12-10 09:33:19 Socket (4) | Connecting to IP: 8.18.161.133. | 2018-12-10 09:33:19 Chart #6 has tagged chart #9 for full recalculation. Chartbook: Futures Pair.Cht | 2018-12-10 09:33:19 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:33:19 Socket (3) | Closed. | 2018-12-10 09:33:19 HG-201807-NYMEX [C] 60 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: Futures Pair.Cht | 2018-12-10 09:33:19 HD Request # 90 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:19 HD Request # 90 | Sending historical data logon request message. | 2018-12-10 09:33:19 HD Request # 90 | Requesting Intraday data. Start date-time: 2018-11-28 14:29:52. Record interval: 0. Symbol: NGZ18 | 2018-12-10 09:33:20 HD Request # 90 | Decompressing data. | 2018-12-10 09:33:20 HD Request # 90 | Receiving Intraday data for NG-201812-NYMEX starting at 2018-11-28 14:29:52 | 2018-12-10 09:33:20 Socket (4) | Signaling to core to close socket | 2018-12-10 09:33:20 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:20 Historical data download thread signaled to stop. | 2018-12-10 09:33:20 HD Request # 90 | Received 1 record from 2018-11-28 14:29:52 to 2018-11-28 14:29:52 (0.0 seconds) and wrote 0 records for NG-201812-NYMEX | 2018-12-10 09:33:20 HD Request # 90 | Completion time: 1s | 2018-12-10 09:33:20 HD Request # 90 | Intraday data download complete for NG-201812-NYMEX. Unique request ID: 81 | 2018-12-10 09:33:20 Removed historical data download ID 81 | 2018-12-10 09:33:20 Real-time Intraday chart data file updates started for NG-201812-NYMEX | 2018-12-10 09:33:20 Intraday chart data file opened for NG-201812-NYMEX | 2018-12-10 09:33:20 HD Request # 91 | Downloading Intraday chart data for UTIS-NYSE to the file UTIS-NYSE.scid. Service: statscalc | 2018-12-10 09:33:20 HD Request # 91 | Download start date-time: 2018-12-10 09:32:46.000 | 2018-12-10 09:33:20 HD Request # 91 | Using server: ds3.sierracharts.com port 10149 | 2018-12-10 09:33:20 Socket (3) | Creating socket. | 2018-12-10 09:33:20 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-12-10 09:33:20 Socket (4) | Socket gracefully closed by remote side. | 2018-12-10 09:33:20 Socket (4) | Closed. | 2018-12-10 09:33:20 HD Request # 91 | Setting DTC encoding to Binary VLS | 2018-12-10 09:33:20 HD Request # 91 | Sending historical data logon request message. | 2018-12-10 09:33:20 HD Request # 91 | Requesting Intraday data. Start date-time: 2018-12-10 09:32:46. Record interval: 0. Symbol: UTIS-NYSE | 2018-12-10 09:33:21 Opened cached Intraday file: C:\SierraChart\Data\NQ-201812-GLOBEX.scid | 2018-12-10 09:33:21 HD Request # 91 | Decompressing data. | 2018-12-10 09:33:21 HD Request # 91 | Receiving Intraday data for UTIS-NYSE starting at 2018-12-10 09:32:46 | 2018-12-10 09:33:21 HD Request # 91 | Timestamp of first Intraday data file record written: 2018-12-10 09:32:47 | 2018-12-10 09:33:21 Socket (3) | Signaling to core to close socket | 2018-12-10 09:33:21 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-10 09:33:21 Historical data download thread signaled to stop. | 2018-12-10 09:33:21 HD Request # 91 | Received 31 records from 2018-12-10 09:32:46 to 2018-12-10 09:33:17 (31.0 seconds) and wrote 30 records for UTIS-NYSE | 2018-12-10 09:33:21 HD Request # 91 | Completion time: 0s | 2018-12-10 09:33:21 HD Request # 91 | Intraday data download complete for UTIS-NYSE. Unique request ID: 82 | 2018-12-10 09:33:21 Removed historical data download ID 82 | 2018-12-10 09:33:21 Real-time Intraday chart data file updates started for UTIS-NYSE | 2018-12-10 09:33:21 Intraday chart data file opened for UTIS-NYSE | 2018-12-10 09:33:21 Socket (3) | Socket gracefully closed by remote side. | 2018-12-10 09:33:21 Socket (3) | Closed. | 2018-12-10 09:33:21 + Loading additional symbol data. | 2018-12-10 09:33:23 Opened cached Intraday file: C:\SierraChart\Data\ZF-201903-ECBOT.scid | 2018-12-10 09:33:24 Opened cached Intraday file: C:\SierraChart\Data\GC-201812-NYMEX.scid | 2018-12-10 09:33:24 Opened cached Intraday file: C:\SierraChart\Data\UTIS-NYSE.scid | 2018-12-10 09:33:24 Opened cached Intraday file: C:\SierraChart\Data\UB-201903-ECBOT-USD.scid | 2018-12-10 09:33:30 + Loading additional symbol data. | 2018-12-10 09:33:57 ASHR-STK-SMART [C-D] Daily #1 | Reloading chart. | 2018-12-10 09:34:24 ASHR-STK-SMART [C-D] Daily #1 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2018-12-10 09:34:24 ASHR-STK-SMART [C-D] Daily #1 | There are no continuous futures contract symbols. Loading data normally. | 2018-12-10 09:34:24 HD Request # 92 | Downloading Historical Daily chart data for ASHR-STK-SMART. Starting date: 2018-12-03. Service: interactive_brokers.trading | 2018-12-10 09:34:24 HD Request # 92 | Requesting historical Daily data for ASHR starting at 2018-12-02 | 2018-12-10 09:34:24 HTTPS historicaldata.sierrachart.com:443 (3) | Creating socket. Using TLS 1.2. | 2018-12-10 09:34:24 HTTPS historicaldata.sierrachart.com:443 (3) | Connecting to IP: 88.99.0.216. | 2018-12-10 09:34:24 HD Request # 92 | Receiving historical Daily data for ASHR-STK-SMART starting at 2018-12-03 | 2018-12-10 09:34:26 HD Request # 92 | Writing historical Daily data to the file ASHR-STK-SMART.dly | 2018-12-10 09:34:26 HD Request # 92 | Received 4 records from 2018-12-03 00:00:00 to 2018-12-07 00:00:00 (5.0 days) and wrote 4 records for ASHR-STK-SMART | 2018-12-10 09:34:26 HD Request # 92 | Completion time: 2s | 2018-12-10 09:34:26 HD Request # 92 | Daily data download complete for ASHR-STK-SMART. Unique request ID: 94 | 2018-12-10 09:34:26 Removed historical data download ID 94 | 2018-12-10 09:34:26 ASHR-STK-SMART [C-D] Daily #1 | Reloading chart. | 2018-12-10 09:34:26 ASHR-STK-SMART [C-D] Daily #1 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2018-12-10 09:34:26 ASHR-STK-SMART [C-D] Daily #1 | There are no continuous futures contract symbols. Loading data normally. | 2018-12-10 09:34:26 ASHR-STK-SMART [C-D] 60 Min #1 | Reloading chart. | 2018-12-10 09:34:28 ASHR-STK-SMART [C-D] 60 Min #1 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2018-12-10 09:34:28 ASHR-STK-SMART [C-D] 60 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2018-12-10 09:34:28 |
[2018-12-10 20:12:56] |
This is the relevant message: HD Request # 79 | Message from IB: The contract description specified for ASHR is ambiguous. IB Error Code: 200. Request ID: 200011. | 2018-12-10 09:33:12 You need to use the more detailed symbol format explained here: Interactive Brokers Symbols: Stocks With Specified Exchange and Primary Exchange Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-10 20:13:09
