Date/Time: Thu, 23 Jan 2025 14:43:10 +0000
[User Discussion] - How to install using WINE? (Linux)
View Count: 1127
[2018-12-04 13:28:06]
User284663 - Posts: 44
Hello, I have recently been testing a Linux distro called Zorin OS which I've been booting from USB, I can't seem to work out how to install and run Sierra Chart using wine and I'm looking for step by step guidance, preferably I would like to avoid the codes, but I'll do what's required, any takers?
*Cricket chirping*
[2018-12-04 14:02:12]
ganz - Posts: 1048
User284663
you should check your hrdwr first
open terminal
~> dmesg | grep -i Error
~> dmesg | grep -i fail
~> dmesg | grep -i bug
Date Time Of Last Edit: 2018-12-04 14:03:10
[2018-12-04 16:27:31]
ganz - Posts: 1048
User284663
another point is to find and check HCL
4 exml: http://h10032.www1.hp.com/ctg/Manual/c00060684.pdf
so there is no any reason to build a setup using unsupported WINE atop on unsupported hardware.
just don't do it.
Date Time Of Last Edit: 2018-12-04 16:28:14
