Date/Time: Thu, 23 Jan 2025 18:10:51 +0000
spreadsheet daily high value issue
View Count: 626
[2018-12-04 13:18:29] |
sierrasimon - Posts: 51 |
Hi, in backtest with spreadsheet, the daily high is a value of the past days, see attachment. Do I miss some adjustment?
SC daily high value.JPG / V - Attached On 2018-12-04 13:16:40 UTC - Size: 291.52 KB - 268 views |
[2018-12-04 18:07:06] |
Yes that is true. It does not reset and only includes the trading activity during the back test/replay. We will make a note of that.
[2018-12-05 16:22:24] |
Is it possible for you to change the daily high in that way, that it really yust show the current daily high? because its hard or impossible to programm that in spreadsheet by myselve. Would be great! Thanks.
