Date/Time: Thu, 23 Jan 2025 14:40:48 +0000
Is there a keyboard hotkey to take control of the SC window/DOM?
View Count: 1010
[2018-12-04 11:01:35] |
Calculus - Posts: 101 |
I used to use Button Trader until IB tragically forced it to close, and on that program it had a really useful hotkey - the ability to highlight the Button Trader window when another program/window was being used. For example, if you're surfing using Firefox any hotkey will only work on Firefox. It's only when the mouse moves to take control of another window, say Sierra Chart, that the hotkeys start work for Sierra Chart. Having a hotkey that highlights the SC DOM is very useful because you might suddenly want to exit/enter at market using a programmed hotkey but your computer is currently in control of the Firefox window or another unrelated program/window. Is there such a facility/hotkey with SC, I've looked around the help but cannot see one. Thanks for reading. |
[2018-12-04 18:21:40] |
We are quite certain you can use an external program for this. For example have a look at Auto Hot Key. And one way that you can help identify a particular window and Sierra Chart is using a custom title bar name: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TitleBarName Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
