Date/Time: Thu, 23 Jan 2025 14:38:02 +0000
TPO Merge in all Charts?
View Count: 646
[2018-12-04 10:02:34] |
novaxt123 - Posts: 43 |
Hello I'm merging for example in the 6E Future 2 days in the TPO chart. If I then load an other futures into this TPO chart these days are also merged. Why is that? What does one have to do with the other future? How can I prevent this? What do I have to do? Thanks Best regards Jan Rabe |
[2018-12-04 10:15:33] |
Do you mean you are changing the symbol of the chart? And you want to merging to automatically clear when you do that? There is no way to automatically clear the merging in this case.
