Date/Time: Thu, 23 Jan 2025 14:34:59 +0000
Build 1842 does not unload dll after custom study is removed
View Count: 1573
[2018-12-04 06:23:47] |
User563013 - Posts: 11 |
I am compiling with visual studio, I get this error after loading the study, testing it, and then removing it from the custom studies window: Error LNK1104 cannot open file '..\..\..\..\..\..\GreenChart\Data\{the file name}.dll' Sierra chart is not unloading the custom study dll after it is not used, and keeps the file handle open. (I can't delete the custom study .dll either) In previous builds (well before 1842 like 1600's) it would allow me to recompile if I removed the dll from the custom study menu. Is there a way to unload the .dll so I don't have to start Sierra chart every time I want to make a change to a custom study? Date Time Of Last Edit: 2018-12-04 06:25:03
[2018-12-04 07:27:59] |
How to do this is explained here: Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-04 09:55:08] |
TedMar - Posts: 190 |
u can use scripts too ACSIL: Example build script using udp commands to unload / load dlls |
