Date/Time: Sat, 25 Jan 2025 00:43:41 +0000
HOW TO ADD CHART TITLES?
View Count: 1511
[2018-12-04 01:29:47]
User80732 - Posts: 26
Hi there,
how am I able to include a title on my charts? Such as what is displayed in the attachment (emini nasdaq) ?....
imageEURNOK.PNG / V - Attached On 2018-12-04 01:28:46 UTC - Size: 110.62 KB - 415 views
imageEmini nasdaq.PNG / V - Attached On 2018-12-04 01:29:07 UTC - Size: 521.39 KB - 649 views
[2018-12-04 01:55:54]
Xfanman1 - Posts: 320
Use the Symbol Display Study. You’ll find the information here —>
Symbol Display
You’ll need to play with the settings to position the text where you want it displayed.
Oh...and nice chart (it’s mine ;^)
Scott
[2018-12-04 02:04:33]
Xfanman!! YES! This is in fact your chart. What is it they say, "emulation is the greatest form of flattery"
I was actually searching out the support board, because I want a dark theme. I came across what seemed to be some work-around solutions that you had posted.
What is currently the most up-to-date, and best way in your opinion to create a dark-theme??
Thanks a bunch for the prompt reply, and nice charts ;)
[2018-12-04 02:11:45]
ALSO, are you aware of a way for they symbol display to also include the Time Frame of the particular chart it's on??
After playing around with the study I'm not seeing anything, but thought I'd ask. Thanks in advance!
for example:
USDCAD DLY
USDCAD 4HR
USDCAD 60M
[2018-12-04 02:30:43]
Greetings!
The best way currently that I’m aware of for a true Dark theme is still to use Stardocks WindowBlinds. It’s cheap and it works. Some day SC may give us control over all of the platforms colors but that’s the best option I’ve come up with until then.
I don’t know of a way to add the chart timeframe as you’re asking. A number of people have requested it (me included) and if I remember correctly the support team mentioned they would add that functionality. I haven’t seen that happen yet (unless I missed it somewhere) but I’m still hopeful they’ll get around to it.
Thanks much.... Scott
Date Time Of Last Edit: 2018-12-04 02:31:54
[2018-12-04 05:01:40]
Big big thanks Scott! Thanks for your reply and help :) Hope you keep killing it in the market!
[2018-12-04 13:11:31]
User371906 - Posts: 141
Scott,
May I ask what pivots you use for your chart?
Tried any times to get the same results from other platform using SC pivot points # 5 (camarilla pivot points) but never seems the same.
Kudos on you chart, super.......
Regards
g
[2018-12-04 14:41:28]
Good Morning G,
I use the standard floor pivots (#1 I think but I’ll check when I get home shortly Edit, I'm using 0 formula type on the Daily Pivot study). I’ve never had a problem with the pivot levels that I remember.
Scott
Date Time Of Last Edit: 2018-12-04 15:35:47
[2018-12-04 16:31:48]
Scott,
Thanks for answer.
Do place the floor pivot points directly over your Flex Renko chart or use regular candles and then overlay then?
Could you please compare your pivot and tell me if they are plotted the same as my ES Dec. contract chart?
http://www.sierrachart.com/image.php?Image=1543940901820.png
I have been using these (https://jacobsladderstradinglevels.com) pivots but would like to compare to SC study # 0.
Kindly
g
[2018-12-04 18:15:21]
G,
Attached is a snapshot of the PP main pivot and S.5 on today's ES for comparison purposes. Hopefully this helps you out.
To answer your other question, yes I simply use the Pivot Study on the Renko charts directly.
Scott
imagePivot Levels.PNG / V - Attached On 2018-12-04 18:15:04 UTC - Size: 26.29 KB - 353 views
[2018-12-04 18:27:45]
Scott,
Yup, for some reason I get different level numbers:
S5 2782.25
PP 2792.75
These are my settings, I dont understand why.......
g
imagePP Settings.JPG / V - Attached On 2018-12-04 18:26:31 UTC - Size: 59.97 KB - 291 views
[2019-02-08 20:18:00]
Scott,
Good afternoon,
I hope you remember me from the Sierra Chart forum when you once answered one question of mine regarding pivots.
I would like to ask you how you are able to keep in the control bar you set with (MARKET - BID – MARKET – ASK – EVEN – FLAT/CANCEL) to that it stays always on top of the chart?
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=24084
Once again Thanks
Kindly
g
