Date/Time: Sun, 24 Nov 2024 16:37:16 +0000
[User Discussion] - zig zag info
View Count: 1859
[2013-11-06 13:19:17] |
djcurcio - Posts: 236 |
For ES, Is there a way to emit the Zig Zag Length (points), the Zig Zag Volume (is this contracts or trades?), and the Zig Zag Duration (elapsed time for the segment) so that they can be plotted. I would like to plot this data as three separate histograms and NOT have a timeline, but simply a bar for each occurrence. Thanks |
[2013-11-06 18:54:43] |
vegasfoster - Posts: 444 |
The easiest thing would be to create a spreadsheet study. I looked at the code and it's too complicated for me to create a custom study using ASCIL, unless someone else wants to give it a go. I can work on a spreadsheet study in next couple days if that solution would be acceptable.
[2013-11-06 19:02:01] |
OK - thanks for your help 2 Questions. 1 - can I use Open Office Calc - I don't have Excel 2 - Will the spread sheet update in real time showing each entry on a new line? thanks again |
[2013-11-06 19:07:17] |
SC has a built in spreadsheet, so you don't need an external spreadsheet, and it will update in real time. I will create a chartbook that will have everything in it so you can see.
[2013-11-06 20:47:52] |
great I will owe you a beer lol |
[2013-11-09 23:56:29] |
I still got this on my to do list, scheduled for tomorrow. :)
[2013-11-10 16:09:01] |
Here's the basic concept. It has a single spreadsheet with the calculations, then you can output them however you like. It's set for 10000 rows, change that as desired. Lemme know if that's what you're thinkin.
[2013-11-10 16:10:54] |
Can't post attachments in this thread either, go here ZigZag Chartbook | Post: 16608
[2013-11-11 23:59:37] |
Sierra Chart - Max - Posts: 5730 |
I just ran some tests, and do not see an issue with uploads. What browser are you using? What type of file did you try uploading?
Sierra Chart Support |
[2013-11-13 19:25:52] |
I loaded the .cht file into Sierra ... data but only get a blank screen. Help? LOL
[2013-11-14 01:51:36] |
Did you change the symbol? I may have a different feed.
[2013-11-14 11:45:44] |
I loaded the .cht file and get "invalid file type - a new blank spreadsheet
[2013-11-15 03:21:57] |
What version of SC are you using? Are you using the non-.net version of SC?
[2013-11-19 16:04:25] |
Version 1042 Sorry for the delay - I've been down a few days Regards dj |
