Date/Time: Thu, 23 Jan 2025 14:26:54 +0000
Occasional trouble with entering trade with cross-hair.
View Count: 544
[2018-12-03 16:54:49] |
User388767 - Posts: 10 |
Last Thursday around 1 p.m. Central I entered a limit order trade with the cross-hair. The values in the window were correct but when I entered the limit order it was entered as a MARKET order. I flattened and cancelled the order thinking perhaps I had done something wrong (though I've been entering orders this way for months with no problems). I tried again. Same thing. I then moved my intended limit order about 5 pts away from the market value. It placed another market order. After that I closed all windows and re-booted the system. After the re-boot, the same problem occurred on the first trade and then straightened itself out with subsequent trades. (NOTE: I had this problem one day months ago but it straightened itself out and has been working properly since.) Today, all started out well enough on the first trade. On the second trade, the same problem occurred. Just finished a trial trade away from market value and it entered properly. Have no idea what it will do next. I haven't changed any settings. Whatever the problem is it appears intermittent. Your attention to this matter will be greatly appreciated. David |
[2018-12-03 19:45:03] |
Check the Chart DOM order type settings to make sure they are correct: Global Trade Settings Windows: Chart DOM Settings There may also be a problem with the bid and ask prices causing an issue where the order type is not as expected based on the settings. You can check those in the Window >> Current Quote Window. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-03 19:45:36
