Date/Time: Thu, 23 Jan 2025 14:38:29 +0000
Everything is Resized upon Start-up
View Count: 552
[2018-12-03 13:01:30]
macguerra - Posts: 20
Anyone else have an issue where EVERYTHING is resized upon start-up. It's a jumbled mess of chart windows where my chart text is now 14 from 8, where I had it and saved it many time over, and consequently affecting my entire layout. Requiring me now to reconfigure everything instead of prep for the trading day!
[2018-12-03 19:14:48]
In some cases this may be an operating system issue:
Window Size and Position Not Restored When Opening Chartbook
If the position of a detached chart window changes from where you saved it after reopening a Chartbook, we want you to use prerelease 1849 and see if that resolves the issue. We removed code, that detects if a chart is offscreen and moves it back on screen and that could be causing an unexpected problem.
Here are the instructions to update to the "Prerelease":
And if the text size is different that is also going to be an operating system problem but we recommend checking the font sizes and resetting them in Graphics Settings:
Graphics Settings: Fonts and Text Appearance
