Date/Time: Thu, 23 Jan 2025 14:40:12 +0000
Study problems in 1848
View Count: 925
[2018-12-03 09:49:48]
User816220 - Posts: 80
I updated from 1842 to 1848 and hit several problems with my existing chartbooks. The below were all reproduced with fresh charts and chartbooks in safe mode. I tested with ESZ18; spot checks showed other futures and equities symbols were affected as well.
1 - The "Volume Weighted Average Price" study causes the chart to continually reload if "Base on Underlying Data" is set to yes.
2 - Adding the "TPO Profile Chart" study blanks out the chart and x/y axis values.
3 - Adding the "Number Bars" study blanks out the display, but still shows values on the x/y axis.
For #2 and #3, opening the attached chartbook shows:
1. Initial chart loading message
2. Chart displays for a moment
3. Chart reloads once
4. Blank chart as mentioned above
attachment1848.Cht - Attached On 2018-12-03 09:24:12 UTC - Size: 90.12 KB - 439 views
[2018-12-03 15:53:06]
Spinoza - Posts: 62
Yes. I had charts continually reloading too and had to revert to 1842.
[2018-12-03 16:07:16]
We are resolving this now. The cause is a very minor issue related to checking for certain types of required data for alert formulas.
Date Time Of Last Edit: 2018-12-03 16:07:32
