Date/Time: Thu, 23 Jan 2025 14:30:09 +0000
Main Price Graph Identifiers
View Count: 753
[2018-12-02 16:29:05] |
user8888 - Posts: 159 |
The Renko O & C can be refered as ID0.SG22 & SG23 is it posible to address also the renko L & H ? in negative case, could you please create them? Thank you! |
[2018-12-02 21:03:35] |
You just need to use H and L in the case of when using Simple Alert Formulas.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-02 21:03:55
