Date/Time: Thu, 17 Sep 2026 13:03:38 +0000
ZN,ZB,ZF, a problem to have the right price.
View Count: 1038
| [2018-12-02 14:58:39] |
| User210074 - Posts: 63 |
Hello, I try to find the right price for the ZB /*...*/ if(TS[i].Type==SC_TS_BID||TS[i].Type==SC_TS_ASK){ int PT=(int)TS[i].Price; /* Price -> 13956250 */ string Test = to_string(PT)+" : "+to_string(DD)+" : "+to_string(FC)+" : "+to_string(IM)+" : "+to_string((float)PT*DD)+" = "+to_string(sc.Close[sc.Index]); sc.AddMessageToLog(Test.c_str(),1); } How do you get the same price value as the right price ? |
Private File |
| [2018-12-02 21:09:27] |
The first step is to get a precise double precision floating point value for these bond prices. And in the next release we are going to add this function to do what you require: double sc.CreateDoublePrecisionPrice(const float PriceValue)
{ return Round(PriceValue / TickSize)*TickSize; } We will have a new release out later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-02 21:10:51
| [2018-12-02 22:25:57] |
Thanks, The code works with all other indices except for ZN, ZF, ZB. I will wait for the update. |
