Date/Time: Sun, 15 Dec 2024 06:52:39 +0000
Converting S5 Trader Strategy Configurations to Sierra Chart
View Count: 1269
[2018-12-02 11:40:40] |
User718622 - Posts: 57 |
How do I go about converting S5 Trader Strategy saved configurations into Sierra Chart? Are the configurations easily importable from S5 into Sierra Chart?
[2018-12-02 23:11:50] |
This is not supported, you just need to re-create them within Sierra Chart: Attached Orders Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-12-02 23:18:09] |
I see. Now, when I recreate them, would I be able to use the configurations within an ACSIL study? Would I be able to share these configurations with another Sierra Chart user? I assume, that once you enable server side brackets and OCO that the saved Sierra Chart configurations would automatically become handled by the server like Gain Capital/OEC and not Sierra Charts. Would I be correct in my assumption? |
[2018-12-03 00:01:09] |
The answer is yes to all of these questions.
[2018-12-03 00:43:24] |
Now, if a certain configuration was required for an ACSIL study, is there any way to bundle it with the DLL so that anyone who gets that study also gets the configuration? Is there any that the connection between the configuration and ACSIL to be abstracted so it is not reliant on one system? For instance, I can use a configuration in my Sierra Charts in an ACSIL study, but how ca I be sure it will be the same if I give both that study and configuration to some else to use in their Sierra Chart? Since you can use tehse configurations in an ACSIL study, can you provide a link to where I might start in the documentation? Or would that simply be the link already provide above? |
[2018-12-03 20:43:39] |
Now, if a certain configuration was required for an ACSIL study, is there any way to bundle it with the DLL so that anyone who gets that study also gets the configuration? Yes this is supported with the Sierra Chart file redistribution system. For instance, I can use a configuration in my Sierra Charts in an ACSIL study, but how ca I be sure it will be the same if I give both that study and configuration to some else to use in their Sierra Chart? This is supported and the configuration will be the same. But the configuration does store the trade account identifier that is currently selected but it gets automatically reset when it is loaded into another users Trade Window. You just want to make sure you have Trade Simulation Mode enabled when saving the Trade Window configuration so you are not saving a Live account number.Since you can use tehse configurations in an ACSIL study, can you provide a link to where I might start in the documentation? Or would that simply be the link already provide above? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-03 20:44:32
