Date/Time: Sun, 24 Nov 2024 13:49:57 +0000
Numbers Bars options
View Count: 1244
[2013-11-05 21:10:08]
Rino - Posts: 124
Would like to be able to set a higher level then the 76-100% color to
use with the "Text On Dominant Side Auction" in text
Coloring Method.
PS Would like to just highlight the extreme imbalances.
[2013-11-06 00:26:48]
You can control this through the Input settings with the Numbers Bars study.
Refer to:
http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#InputSettings
We realize, that it is not possible to set a value greater than 100%. We do not have a solution to offer for this now.
Date Time Of Last Edit: 2013-11-06 00:28:53
