Date/Time: Thu, 23 Jan 2025 14:30:33 +0000
Trade Statistics Page Error, SC Version 1842
View Count: 850
[2018-12-01 17:13:49] |
User327694 - Posts: 25 |
In Trade Statistics, IF a change is made to the date range or symbol and applied, AND the number of rows required for the new statistics page is FEWER, then the extra rows from the previous statistics page are still shown. This is easily reproduced by showing statistics for a bunch of trades for a particular symbol or date range, and then changing and applying a symbol or date range that has no trades. I can tell you I am seeing this problem with extra Consecutive Losers statistics when switching to symbols or date ranges trades with fewer/shorter consecutive loser/winner runs. Thanks. |
[2018-12-01 21:19:10] |
This will be solved in the next release.
