Date/Time: Thu, 23 Jan 2025 14:36:01 +0000
tool - arrow
View Count: 1169
[2018-12-01 10:39:37] |
User633898 - Posts: 28 |
Hi, Can you please advise how to activate the arrow tool? Thanks |
[2018-12-03 20:19:22] |
To use the Arrow tool, simply select Arrow from the Tools menu and left-click once to set the base of the arrow, and a second left-click to set the arrow point end of the arrow. Refer to the following for information on the Chart Drawing Tools: Chart Drawing Tools If you are referring to how to do this in ACSIL, then refer to the following documentation: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
