Date/Time: Thu, 23 Jan 2025 14:45:38 +0000
[Programming Help] - ACSIL: SCTimeAndSalesArray - no longer valid in 1842
View Count: 632
[2018-12-01 10:02:35] |
BlakJak - Posts: 108 |
I re-compiled my study code today since I upgraded to 1842 and I have found that "SCTimeAndSalesArray" no longer exists. I found "c_SCTimeAndSalesArray" but this is undocumented and code examples on the Sierra Chart documentation still refer to "SCTimeAndSalesArray". Has a change been made? If so, what is the reason for the change and will there be more of the same? |
[2018-12-01 10:04:03] |
We will update the documentation. This was renamed to follow a standard format for class names but we did not realize at that moment it was part of ACSIL.
