Date/Time: Thu, 23 Jan 2025 14:29:20 +0000
tool bar
View Count: 533
[2018-12-01 09:25:28] |
User633898 - Posts: 28 |
Hi, I accidentally lost the tool bar on top of the chart which provide a number of short cut buttons. Could you enlighten me how to retrieve this? Thanks |
[2018-12-01 09:44:14] |
You just need to follow the instructions here: Control Bar: Window >> Control Bars >> Control Bar [1-12] Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
