Date/Time: Thu, 23 Jan 2025 14:31:16 +0000
[User Discussion] - Flicker chart
View Count: 712
[2018-12-01 04:54:24]
SkyKeeper - Posts: 40
There is a flicker of the schedule when a new bar arrives. For verification, I took version 1705 on it, everything is in order. 1805 and above flickers. The background is black. BarSpacing 0-1 high flicker, 2 medium flicker, 3.. low flicker
[2018-12-01 09:40:32]
So you are saying a chart is flickering? Does not really make much sense unless there is a problem with the creation of bitmaps but that would be highly unlikely.
Date Time Of Last Edit: 2018-12-01 09:40:45
[2018-12-01 10:25:42]
Yes flickers. Noticeably on a black background. But for a split second, the brightness of the bars decreases and then returns. You can also notice if you move the chart with the arrow to the right.
the stronger the chart bar spacing, the more noticeable the effect
Date Time Of Last Edit: 2018-12-01 10:26:57
