Date/Time: Thu, 23 Jan 2025 14:36:26 +0000
Simple bracket order with limit sell and limit buy
View Count: 1376
[2018-11-30 21:51:29] |
User450179 - Posts: 105 |
HI, I am stumoed on how to setup a bracket order with 2 limits at he same time. sounds easy but i want them attached and i do not want one to cancel if one gets filled. example. nasdaq at 6960 Bracket: sell limit 6970 buy limit 6950 if i move the buy up a tick I want the sell limit to move up a tick. I want this to be manual. when one side gets filled I want the other side to remain on the book. another example that would fill sooner would be.. mkt at 6960 sell limit 6961 buy limit 6959 i do not care which one fills first. I need to be able to move one side and have the other side move up or down to keep my "spread" the same. I will manually be moving one side of the order and the other side should move with it. lastly, when one side is filled the other order does not cancel it stays with it's original priority on the book. thanks JAY p.s. This is a nondirectional strategy that would allow me to keep the opposite (offset) trade on the book with a better time priority. I have tried lots of different bracket but cannot figure out how to make this one work. THank you |
[2018-12-01 09:48:59] |
This really is not directly supported because this involves two Limit orders of different sides. Attached Orders support Target orders and Stop orders of the same side.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-01 09:49:27
