Date/Time: Sat, 19 Sep 2026 13:20:38 +0000
[Programming Help] - ACSIL: how to query bar color at runtime
View Count: 1578
| [2018-11-30 17:47:59] |
| User525733 - Posts: 126 |
Hi, Is there a ACSIL function to retrieve the color of the current bar? ...aka....color at sc.BaseData[sc.Index] fyi, I am using renko bars if that matters. thanks |
| [2018-12-01 02:29:46] |
some more clarification: i would like to find the color of the current bar (or a previous bar) using an ACSIL function....i.e whether it is a green (up bar) or red (down bar). is there a builtin ACSIL function to do this? if not, any recommendation how to go about getting the bar's color? thanks again |
| [2018-12-01 22:30:53] |
| [2018-12-02 16:12:21] |
| ForgivingComputers.com - Posts: 1238 |
is there a builtin ACSIL function to do this? if not, any recommendation how to go about getting the bar's color? Subtract the open price from the close/last price and check to see if the bar has closed. If it is positive, then the bar is up, negative means down. int BarColor;
if ((sc.BaseDataIn[SC_LAST][sc.Index] - sc.BaseDataIn[SC_OPEN][sc.Index]) >= 0 && sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED) BarColor = 1; // Green if ((sc.BaseDataIn[SC_LAST][sc.Index] - sc.BaseDataIn[SC_OPEN][sc.Index]) < 0 && sc.GetBarHasClosedStatus() == BHCS_BAR_HAS_CLOSED) BarColor = 0; // Red |
| [2018-12-02 16:36:26] |
thanks Brad
