Date/Time: Sat, 26 Apr 2025 15:40:45 +0000
Chart - Reversal across contracts
View Count: 528
[2018-11-30 13:42:32]
User150852 - Posts: 38
I am using reversal chart and having issue using the same chart book across symbols, .e.g ES and 6E - the reversal size is dependent on the symbol's cardinality...
Is there a way to make the reversal setting somehow aware of the symbol (maybe have the user input a table with two columns - symbol and value) or do i need to create a separate chart book for each symbol (which will cause some headache as i will need to maintain\update multiple chartbooks which are almost the same.
