Date/Time: Thu, 23 Jan 2025 14:43:05 +0000
Sub instance data gap
View Count: 824
[2018-11-30 09:56:52]
User907968 - Posts: 825
Hi support,
Since switching to using SC in server/client (main instance + 4 sub instances on local computer), the data download upon initially opening the charts is not complete.
It appears that the intraday data from the historical data server is downloaded completely, but the intraday data from the live server only begins from the time the chart is opened. Please see the attached image captured immediately after opening the chartbook, this shows a 10-min gap.
Performing a 'reload & recalculate' makes no difference, the charts reload exactly the same.
Performing a 'delete & download data' does fill in the missing data, however this must be repeated for each and every symbol anytime that the incoming data feed has been disconnected.
The observed behaviour is consistent across all symbols monitored (CME & NYMEX), the data feed is CTS T4 FIX, SC is set to 'periodically set system date time from server'.
I have reviewed the help documents, but cannot find a solution, am I missing something obvious?
edit - I forgot to upload the image, sorry
Date Time Of Last Edit: 2018-11-30 11:17:29
imagedata gap.png / V - Attached On 2018-11-30 11:16:59 UTC - Size: 77.85 KB - 285 views
[2018-11-30 17:02:03]
Next time you notice this when you start a sub instance, provide a copy of the Message Log following these instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
And tell us one of the symbols it happens with.
Date Time Of Last Edit: 2018-11-30 17:02:45
[2018-11-30 18:06:25]
Hi support, logs submitted for analysis, 1800GMT, both for main instance and sub instance.
The symbol is CL.20190100.CME_NY
Thank you.
imagedata gap CL.png / V - Attached On 2018-11-30 18:05:37 UTC - Size: 64 KB - 266 views
[2018-12-01 08:29:35]
This is not something we usually recommend but we want you to perform a Full Reset of the Symbol Settings:
https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps
It is hard to definitively say but it appears as though there is either missing symbol settings or something wrong with the rollover rules causing Sierra Chart to think CL.20190100.CME_NY is an expired contract.
[2018-12-01 08:41:28]
Actually the answer given at post #4 might not be correct. There is some complexity going on here.
We want you to disable Global Settings >> Data/Trade Service Settings >> Allows Support for Sierra Chart Data Feeds.
[2018-12-01 09:41:39]
We have determined the reason for the problem and a solution will be implemented in the next release. It has to do with a two-step download from the Sierra Chart Historical Data Service and then from the primary service.
[2018-12-01 12:25:29]
Based on your last post, can I assume that posts 4 & 5 no longer apply?
Thank you for looking at this so quickly.
[2018-12-01 20:57:52]
Post #5 is the solution to use right now. But we expect to have a new release out tomorrow.
[2018-12-03 16:44:53]
This issue seems resolved now in v1849, thanks.
