Date/Time: Thu, 23 Jan 2025 14:42:14 +0000
No Dax data through Sierra feed
View Count: 1077
[2018-11-30 07:10:43]
phaedonk - Posts: 352
Can you check on this now? Market is open, no data coming through for this session
[2018-11-30 07:12:42]
User749205 - Posts: 38
Same here.
[2018-11-30 07:16:42]
ticinotrader - Posts: 400
There is no realtime data coming on the SC Feed for GG, HR, FX, II, FN, FA either - all EUREX products. History loaded correctly, but shows the last close. No data for today yet.
Date Time Of Last Edit: 2018-11-30 07:18:11
[2018-11-30 07:22:54]
Okay we are checking on this now.
[2018-11-30 07:25:42]
We have confirmed the issue. Our data provider Barchart is not providing any data on the Open Feed. We are contacting them now.
[2018-11-30 07:30:19]
Give us about 10 to 15 minutes to patch in a backup feed for the major contracts, assuming there are no unexpected complications, in which case it could take longer.
Date Time Of Last Edit: 2018-11-30 07:30:30
[2018-11-30 07:40:38]
User117072 - Posts: 4
I have the same problem on DAX DYZ18, there is no real time data coming only a historical
[2018-11-30 07:54:25]
Yes we know, we are working on a solution now.
[2018-11-30 08:01:50]
Data started streaming, but no backfill
[2018-11-30 08:07:11]
User877753 - Posts: 152
No historical data, no streaming data from EUREX as 9:06.
[2018-11-30 08:11:05]
This is a work in progress. We have the backup data feed operational for the major EUREX contracts on one of our servers. If you are not receiving it, reconnect to the data feed:
Market depth data is only available for the DAX, we are going to bring that in for other contracts in the next few minutes.
As far as historical data goes, we will make sure that is fully available as well. Just give us a few more minutes.
Date Time Of Last Edit: 2018-11-30 08:11:43
[2018-11-30 08:27:53]
The backup feed is now operational for all of the major EUREX contracts on one of the servers. There is complete historical data now.
If you are missing any data in the chart, simply follow the instructions here:
We are only going to keep the backup feed operational on one of the servers. So if you do not have it, just simply reconnect to the data feed. When the Open Feed comes up from Barchart, when they react to our notice to them, that will then be operational on the other server.
We do apologize for this. We are just doing our best.
[2018-11-30 08:37:08]
Okay now the market depth is available for the major contracts.
[2018-11-30 08:41:20]
Also, there are some contracts mentioned in post #3 we do not yet have a backup feed for. Just give us about another 15 minutes for those.
Date Time Of Last Edit: 2018-11-30 08:53:26
