Date/Time: Sun, 24 Nov 2024 13:37:52 +0000
SC feed - Log
View Count: 1268
[2013-11-05 20:16:38]
User14266 - Posts: 225
Just a FYI. I disconnected from the feed(on purpose) and can't reconnect. Back on CTS feed for the time being. You guys probably already know, but just in case you don't. Thanks.
Requesting market depth updates for: ES.CME_20131200_ESZ3.CME_Eq if supported. | 2013-11-05 14:08:56
SC RealTime Futures Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-11-05 14:08:56
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-11-05 14:08:56
The network socket is connected. | 2013-11-05 14:08:56
SC RealTime Futures Data: Connected to server. | 2013-11-05 14:08:56
SC RealTime Futures Data: Sending logon request message. | 2013-11-05 14:08:56
SC RealTime Futures Data: There has been no activity on the network socket. Will reconnect. | 2013-11-05 14:09:36
SC RealTime Futures Data: Disconnected from the server. | 2013-11-05 14:09:36
SC RealTime Futures Data: Data feed disconnected. Will reconnect. | 2013-11-05 14:09:36
SC RealTime Futures Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-11-05 14:09:40
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-11-05 14:09:40
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-05 14:09:42
SC RealTime Futures Data: Disconnected from the server. | 2013-11-05 14:09:42
SC RealTime Futures Data: Data feed disconnected. Will reconnect. | 2013-11-05 14:09:42
SC RealTime Futures Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-11-05 14:09:46
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-11-05 14:09:46
The network socket is connected. | 2013-11-05 14:09:46
SC RealTime Futures Data: Connected to server. | 2013-11-05 14:09:46
SC RealTime Futures Data: Sending logon request message. | 2013-11-05 14:09:46
SC RealTime Futures Data: There has been no activity on the network socket. Will reconnect. | 2013-11-05 14:10:26
SC RealTime Futures Data: Disconnected from the server. | 2013-11-05 14:10:26
SC RealTime Futures Data: Data feed disconnected. Will reconnect. | 2013-11-05 14:10:26
SC RealTime Futures Data: Connecting to the server scdf2.sierracharts.com. Port 443 | 2013-11-05 14:10:30
Resolved address ds7.sierracharts.com to IP 8.18.161.133 | 2013-11-05 14:10:30
Error connecting socket. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2013-11-05 14:10:31
SC RealTime Futures Data: Disconnected from the server. | 2013-11-05 14:10:31
SC RealTime Futures Data: Data feed disconnected. Will reconnect. | 2013-11-05 14:10:31
SC RealTime Futures Data: Connecting to the server scdf1.sierracharts.com. Port 443 | 2013-11-05 14:10:35
Resolved address ds6.sierracharts.com to IP 8.18.161.131 | 2013-11-05 14:10:35
The network socket is connected. | 2013-11-05 14:10:35
SC RealTime Futures Data: Connected to server. | 2013-11-05 14:10:35
SC RealTime Futures Data: Sending logon request message. | 2013-11-05 14:10:35
[2013-11-05 20:41:19]
We apologize for this. This is now all resolved.
You can reenable the Sierra Chart data feed.
