Date/Time: Thu, 23 Jan 2025 14:44:50 +0000
Including Quantity with Custom Trading Keyboard Shortcuts.
View Count: 646
[2018-11-29 19:16:48] |
Yoda - Posts: 106 |
Back in 2017 while discussing Custom Trading Keyboard Shortcuts in: Custom Trading Shortcuts SC Support stated that: Yes we can see about supporting the quantity as well.
Currently, in the Custom Trading Keyboard Shortcuts -> Customize Trading Command, I can set everything except quantity. Would it be possible to add quantity to this? And while on this subject, would it be possible to add the options to choose "open position", "1/2 position", "1/4 position" to the Quantity options? I.e. I would like to setup a Customized Trading Command to: Buy @ Market @ Ask with Offset of 5 and 1000 Shares. I would also like to setup a Customized Trading Command to: Sell @ Market @ Bid with Offset of 5 and 1/2 of my open position. |
[2018-11-29 21:26:46] |
There are keyboard shortcuts that can be set for the 6 quantity buttons on the Trade Window. They are in the list of Trading Keyboard Shortcuts: Basic Trading and the Trade Window: Trading Keyboard Shortcuts Try to configure the quantities you need using just those. This is all we have. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-11-29 21:27:07
