Date/Time: Tue, 04 Feb 2025 06:49:29 +0000
half second bars on chart
View Count: 793
[2018-11-29 16:27:34]
User450179 - Posts: 105
I saw that you guys are working on millisecond tiem stamping which is great adn needed, but I was wondering if this would allow me to
have a "OHLC" bar chart draw at a 500 ms or (half second interval)? Currently 1 second is the lowest i ahve found from a time scale. I undertand I can reduce the
the time interval somewhat by using volume or range or ticks, but i am accustomed to using a time scale for my trading. A 500 ms or .5 second chart capability would be AWESOME!
thank you
[2018-11-29 22:02:58]
Yes that capability can come but probably later on.
[2019-08-09 02:24:27]
are you still planning on implementing this and would I then be able to use it for my precise spread chart?
[2019-08-09 05:08:56]
Yes but we doubt we would be able to get to this until next year.
[2020-01-14 17:12:14]
Hello hope you are having a great day.
is there still a chance you can have 500 millisecond or Half seconds allowed in sierra chart?
this would be 2x as fast as the best service out there which is you! sierra chart
thanks
[2020-01-14 17:33:03]
Not now but later.
